@biomanrose : The so-called MMI 3G "activator" is a QNX/Unix shell script that patches the MMI system to allow use of the nav database following a firmware/software & nav database update, and should only be run after the MMI displays the message "nav database is blocked" (or similar). The "activator" scripts are specific to either 3G (HNav) or 3GP (HN+) systems -- that is, you cannot use the 3GP "activator" script on a 3G system & vice versa. If you do, as you may have, the path forward can be more complicated.
You were correct not to delete the nav database & HDD partition before running the nav database, since you were not changing the database region. My advice is to leave the nav database alone for now and focus on the changes you made to the MMI system software, including the license key (FSC) files that came with your MMI 3G system.
You wrote above that you ran the "FSC Remove" script -- this was a BIG mistake (and an even BIGGER mistake if you didn't save the FSC files the script copied to your SD card as a backup). The "FSC Remove" script is ONLY used to solve the DTC 03623 issue (possibly affects only on 3GP systems). So your current task is to determine whether your HNav system has a valid FSC file in /mnt/efs-persist/FSC directory, and if not, to find your original FSC file and restore it to that directory. --g
