@Stewart M : You are in the correct thread. Update your system software to current first as described in the first post. For the nav system, you should be able to use the 6.34.1 update here:
MMI 3G+/3GP navigation 6.34.1 and firmware updates -... , taking care to prepare your SD card for the 3G High update (unless you use a high quality FAT32 64GB SD card with the complete 3G High/Plus update files). --g
You seem like a knowledgeable and helpful chap, so I will ask you for the help I need.
So I updated my MMI firmware as recommended, one step at a time, until I reached the final 0257_6 (HNav_EU_K0257_6_D1). No problems here, I think.
I then installed the 6.34.1 2022 MMI 3G High/Plus Europe map, as found here:
MMI 3G+/3GP navigation 6.34.1 and firmware updates -..., as per your suggestion yesterday. Now reading Nav. Database Version: 8R0060884JN ECE 6.34.1. I did remove the previous map data, and delete the partition, as suggested in the latest iteration of the guide on that page.
I then ran the activator that was included in the download from that map file. So I kind of have to assume that was the correct one.
When I ran the script, it all looked good, had the press any key to execute the script notice. Pushed the big button, and the screen changed to the radio screen, but with the map "underneath" it. Then after a few minutes, it suggested the map data was blocked.
I rebooted the MMI, went into Nav, opened up the map, all looked good actually. Went to hunt for a new local road, which was there, so looked like it was working again. Then got the message again saying it was blocked.
So went to re-install the activator script, but this time, when clicking to install, it said the activator was already installed.
Went back to Nav, and it states that data is still blocked.
Should I run Vlasoff maps activation? Or is there another activator to use? Should I uninstall the activator that is currently in use? Or will this fix itself after a few reboots?
EDIT:
Further reading has suggested I may have used the incorrect activator. So should I use this one (3GH Activator):
4.35 MB folder on MEGA
If so, what is the process? Can I just run it over the top of the already installed one? Or do I need to remove the old one first? If so, how do I do that?
