Status
Not open for further replies.
541 - 552 of 552 Posts
A8 2015
@Saffa S5
If you're at version P0072, you only need to download K0206, K0253 & K0257-6.
These are RAR files; you need to use WINRAR to expand them to their folders on a Windows PC.
206 will expand to Folders 1, 2, 3 and Metainfo2.txt
253 will expand to many folders and Metainfo2.txt
257 will expand to many folders and metainfo2.txt
These folder sets are 713MB, 556MB & 867MB; you copy them to a blank SD card formatted as FAT32 and install them one at a time, so they easily fit on any SD card bigger than 1 GB.
You have to install via the Red Engineering Menu; I expect they will take about 15-20 mins for each update.
You don't need the Green Engineering menu to install firmware; if you do need it later, it has to be activated by VCDS or an appropriate script file.
@Saffa S5
You have to install via the Red Engineering Menu; I expeou ct they will take about 15-20 mins for each update.
Thank you for the speedy reply. How do I get to the Red Engineering Menu? Also they say you need to watch out what system you have. How do I know if I have a Bose or B&O?
Could someone assist with region change? audi s4 jap import with hnav_jp_k0273 what eu firmware can i use. I understand I need to edit eeprom so correct languages install, im just not sure what firmware to use, can i go straight to K0257-6?
Status
