Keldo's Activator is based on calculator acording wlan Mac adress? I tryed that but not working for me on 2016 maps till I found Vlasoff Activator.
I think that's your problem then. As far as I'm aware, the FSC activator hasn't been verified as working with the latest navi DB. If it were me, I'd uninstall it and use the Keldo activator script that has been confirmed as working.No I had used only the FSC activator and worked fine.
It used to but now is completely automated and I can't see anything in the script referencing MAC addresses.Keldo's Activator is based on calculator acording wlan Mac adress?
So to be clear, the Vlasoff Activator worked for both the 2016 navi DB and 2018 navi DB?I tryed that but not working for me on 2016 maps till I found Vlasoff Activator.
Looking at your posts over on another site, you stated that you still had a 03175 DTC present, under the 5F module, after your update. Have you managed to clear it yet?In my case I used Keldo activator on older 6.25.3 and now erased navi database and partition and updated map only to 6.26.1. All stayed activated. Only if You change firmware then patch stop worrking
Nope still fighting with that, but all is working fine, I mean navi, traffic, mmi so not so important for me. Last resort is to use Vcp zdf file from eu version of q5 3gp mmi but I'm not sure of result and don't want to risk specially that my mmi is converter as I imported my car from USALooking at your posts over on another site, you stated that you still had a 03175 DTC present, under the 5F module, after your update. Have you managed to clear it yet?
Paul
Not with the Keldo activation script you won't. The Keldo script patches the firmware so will remain valid, for each and every navi DB update no matter the workflow you use, until either you change the FW version or Audi change the activation method.If you erase HDD nav partition and nav database before map update then you will lose old activation Im afraid
Great, keep us posted as this is what's holding me off from updating my 3GP. I don't like having random DTCs lingering.Nope still fighting with that, but all is working fine, I mean navi, traffic, mmi so not so important for me. Last resort is to use Vcp zdf file from eu version of q5 3gp mmi but I'm not sure of result and don't want to risk specially that my mmi is converter as I imported my car from USA
I dont know either why Keldo's script didnt work on 2016 db. I generated the code acording wlan Mac adress and put it in the script name instead of "xcode" and it didnt activate nothing. When I use Vlasoff it was fine immediately. Is there a new Keldo Activator or you did the same as I do?Not with the Keldo activation script you won't. The Keldo script patches the firmware so will remain valid, for each and every navi DB update no matter the workflow you use, until either you change the FW version or Audi change the activation method.
I'm not sure why it didn't work for you on the 2016 navi DB but, I'm guessing there was a conflict somewhere. I used it to activate the 6.25.3 navi DB on my 3GP and it worked as expected.
Paul
Right, who knows all say it's totally same as eu unit but.... It's different CDMA only modem inside which works here as 2g only and although I ve changed language matrix in eeprom and firmware to eu one telit modem has different firmware from eu one and never update during firmware change, maybe here is a problem. I found right modem on aliexpress but don't want to pay 100 eur just to have 3g net in car which I use only for Google Search and online traffic, for this 2g is enoughGreat, keep us posted as this is what's holding me off from updating my 3GP. I don't like having random DTCs lingering.
If your car is using the US MMI unit, I wonder if this is a factor for you (regardless of your FW conversion) as it doesn't seem to be an issue for anyone else. At least as far as I've read.
Paul
As I mentioned, the Keldo script is automated now so no need to change any part of it. You can find the links to the installer and uninstaller here.Is there a new Keldo Activator or you did the same as I do?
Yes, makes sense.Right, who knows all say it's totally same as eu unit but.... It's different CDMA only modem inside which works here as 2g only and although I ve changed language matrix in eeprom and firmware to eu one telit modem has different firmware from eu one and never update during firmware change, maybe here is a problem. I found right modem on aliexpress but don't want to pay 100 eur just to have 3g net in car which I use only for Google Search and online traffic, for this 2g is enough
Thank you!As I mentioned, the Keldo script is automated now so no need to change any part of it. You can find the links to the installer and uninstaller here.
Paul
No problem.Thank you!
Ok, and one more thing is Keldo uninstaller is for old Keldo Activator?No problem.
If you use it (or any one you know does), please feedback and let us know how you got on.
Paul
Out of those two, I'd use the DarkDLL script. Can't advise whether it's automated or not though as I've not used it.So which of the 2 should I use?
activator only links
# Activator for HNav 257_6 (ONLY FOR 3G High NOT for 3G Basic)
mega.nz/#!MkZgBDzb!k3tKfgda8...N84JFZXoT1DmZw
Zippyshare.com - _MMI3GH_ACT.zip
# Activator modified by DarkDLL for 3G High
mega.nz/#!EUw3kahY!QJIzerr9V...lJVT1tUoKBrG_w
Do I need to use the calculator to modify the script or I just run it and finish?
Hmm, good question. I'm assuming it's for the latest patch type but could be wrong...Ok, and one more thing is Keldo uninstaller is for old Keldo Activator?
All done and pretty straight forwards as before.Yes, makes sense.
I think I'm going to risk it, you've talked me into it! :smile2:
Paul
