Files aren't right on the SD card - either from downloading/unpacking with a Mac, dodgy download or problems writing to the SD cardHello,
I'm trying to update my maps to 2016. I get AUDI_MMI3G_ECE "?" rather than a "Y" after the metainfo is read. Does anyone have a clue what can be causing this error?
Thanks.
I had a the same problem once. Make sure to use a WIN PC and not a Mac when writing the files to the SD card.Files aren't right on the SD card - either from downloading/unpacking with a Mac, dodgy download or problems writing to the SD card
Your version isn't covered by this thread - you will most likely have to pay someone to activate it, although firmware (not the ones in this thread) are available and you can use the map file itself from this thread.could someone help me with the update please.
I have a A5 from 05.2012 with 3GP+ HDD and without sim. My version is P0530 (see also the attached picture). What must I do to update my MMI?
Thanks for your time
That's a weird descriptor for the version! That appears to be original 2011 map files for 3G but by the looks of it yours has required a DAB specific update with its own firmware levelHi Adrian
Firstly thanks v much for this simple guide.
I just went to kick it off on my 2011 A5 I got last week, and checked my version so I knew where to begin. But my version number seems very different to all those posting here, it doesn't start with "HNav"
Train / Software version: 3G_DAB_K0098
MU Software: 0167
Nav DB: 8R0060884N ECE 5.12.5
So I'm a bit stuck already - as far as I know I have 3G High (Joystick, high res screen, HDD). Do I just kick off from update 0206 (2nd firmware folder)?
Thanks again
Thanks Adrian, I like to be a bit different...That's a weird descriptor for the version! That appears to be original 2011 map files for 3G but by the looks of it yours has required a DAB specific update with its own firmware level
Assuming you have the jukebox function to absolutely 100% confirm this isn't BNav/3G Basic then you should be able to use the files here.
I think you're correct to start with the 2nd level of firmware and go from there![]()
In all honesty I don't know, but I'm not aware of any method to backup the firmware. Since most of the firmware has never been subject to change I would imagine a full download of the firmware on every module would be quite a task. I'm not a coder but I'd also assume it's not as simple as reading it as installed to be able to put it back?Thanks Adrian, I like to be a bit different...
Is there any way to export / backup this firmware just incase? Or will it either work & be fine or fail and rollback to existing?
Thank you very much, I'll do the update as soon as my 32 GB SD card arrives, hopefully with no mess-ups :smile2:.You don't need to update your firmware, but if you want to update it just run the last _6 version. Your firmware level is late enough that it won't mess anything up by doing that :smile2:
