Glad you got updated @Matthew Borrett. Got to take myself the next step up to 257_6_D2 and the 2016 maps when I get another spare 4 hours....
How do you find the Carista + wifi OBD2? I presume it is this from Amazon: http://www.amazon.co.uk/dp/B00YVHGTBM/?tag=carista-21
From you saying you are getting a VCDS to clear the codes I'm guessing it can't do that, so what does it do? I'd prefer to be able to use my phone/iPad to scan and tinker without having to run a virtual windows machine on my Mac laptop and drag that out to the car.
nothing wrong with that.a virtual windows machine on my Mac laptop
The app is free to download from the App Store and I did start out by using their OBD2 connector which is Bluetooth, however I return this and got this one "OBDII OBD2 Diagnostic Wifi Vgate Car Diagnostics Tool,IPAD,IPHONE,ANDROID ICAR2" from Amazon as it connects via wifi which is just my preference.How do you find the Carista + wifi OBD2? I presume it is this from Amazon: Carista OBD2 Adapter and Scanner for iPhone/iPad and Android + Free App: Amazon.co.uk: Car & Motorbike
Free:
Check faults and reset
Shows available customisations but paid version is required to activate them.
Paid (£15 from memory):
Detailed scan and check codes against Ross-tech database
Customisation (depending upon vehicle) but for my A5 these are:
Doors / Windows / Remote:
Auto-lock doors when moving
YES / NO
Auto-unlock doors when key is taken out of ignition
YES / NO
Auto-lock trunk when moving
YES / NO
Beep when alarm is armed
YES / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Enable settings for opening/closing windows and sunroof
YES / NO
Open/close windows and sunroof via long-press on remote
YES / NO
Close windows via long-press on remote
YES / NO
Open windows via long-press on remote
YES / NO
Close sunroof via long-press on remote
YES / NO
Open sunroof via long-press on remote
YES / NO
Sunroof action when opening via remote
SLIDE / TILT
Open/close only driver's window via remote or key
YES / NO
Open/close windows and sunroof via smart key
YES / NO
Close windows via smart key
YES / NO
Close sunroof via smart key
YES / NO
Open/close windows and sunroof by holding key in door lock
YES / NO
Open windows by holding key in door lock
YES / NO
Open sunroof by holding key in door lock
YES / NO
Close windows by holding key in door lock
YES / NO
Close sunroof by holding key in door lock
YES / NO
Close convertible roof via long-press on remote
YES / NO
Close convertible roof by holding key in door lock
YES / NO
Close convertible roof via smart key
YES / NO
Open convertible roof via long-press on remote
YES / NO
Open convertible roof by holding key in door lock
YES / NO
Blink turn signals when done closing windows via remote
YES / NO
Enable remote control when vehicle is running and in gear
YES / NO
Instruments / Display / Dings:
Display warning about using navigation when moving
YES / NO
Gauge needle sweep at startup
YES / NO
Gauge needles lit even when headlights are off
YES / NO
Gauge scales lit even when headlights are off
YES / NO
Seat belt warning
DISABLED / US/CANADA STYLE / EURO STYLE 1 / EURO STYLE 2 / EURO STYLE 3
Navigation disc eject button
ENABLED / DISABLED
Lights:
Allow configuring daytime running lights via dash display
YES / NO
Use front LED lights as daytime running lights
YES / NO
Use fog lights as daytime running lights
YES / NO
Use high beams as daytime running lights
YES / NO
Use tail lights as daytime running lights
YES / NO
Use side marker lights as daytime running lights
YES / NO
Use low beams as daytime running lights
YES / NO
Dim daytime running lights when ignition and parking lights are both on
YES / NO
Turn off daytime running lights ("wink") when turn signal is on
YES / NO
Coming-home lights
ENABLED / DISABLED
Leaving-home lights
ENABLED / DISABLED
Use fog lights as coming-home lights
YES / NO
Use low beams as coming-home lights
YES / NO
Coming-home lights duration
10 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
Turn off front fog lights when high beams are on
YES / NO
Turn off rear fog lights when high beams are on
YES / NO
Flash brake lights in emergency stopping
YES / NO
Flash hazard lights in emergency stopping
YES / NO
Turn on side marker lights with headlights (US models only)
YES / NO
"Euro" parking lights when ignition off, turn signal on
YES / NO
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
YES / NO
Remember position when lowering passenger-side mirror in reverse gear
YES / NO
Nothing much wrong - just more cumbersome and with a wireless + iPad solution I could use it while travelling around, maybe even do some continuous logging. Can't charge the laptop in the car.nothing wrong with that.
doing it all the time![]()
that's my impression too.but i didn'k quite see any diference, by diference i mean the new roads from last year,they don't apear after the new update
one step at a time.Does this mean that I first have to update my firmware twice (first to version 253, and afterwards to version 257) or can I update directly from version 206 to 257 at once?
you must do all 4 of them.I have downloaded the B8 Firmware, there are 4 folders in there, do I have to apply each one at a time or can i just up load the latest?
