Hi, I tried but it doesn't work in my MMIDid you see this?
Convert videos to play on MMI 3G High & Plus - Carsie.net
If you have MMI 3G High or Plus unit you are able to play videos from SDCARD's - however they must be converted to the right format and resolution.upgrademyaudi.net
Thanksthis is what I found in the manual for my A5
I am sure something similar will be in your manual
in short files with an extension .mp4 will not work
Hi, nothing to do is not workingthis is what I found in the manual for my A5
Hi, can you get me a file so that I can test it in my MMI and look at the settings ?, thanksDid you follow the link I sent? Files must be the correct format (frame rate, resolution etc) or they won’t work.
You say you have tried every way. Perhaps more detail on what you have tried will help us help you.
Hi guys, I did the whole procedure as indicated on the video and I don't see anything, but I noticed that the MMI goes into lockdown, even if I try to change the source it tells me that the DVD is not readable and I am forced to do a reset, you know how to give an explanation ?, thanksI don’t play videos in the car. I was just pointing you to resources that should help.
If you need more help please document exactly what you have tried then other members may be able to offer assistance
