1 - 6 of 6 Posts
Hi All, I've just updated my Firmware and maps to 2020 as above but I'm unable to activate. I'm unsure which one to use. Screen is showing "The navigation data is blocked" Can anyone out there give me some advice please? Thanks
178108
178109
178110
Warning : he Vlasoff activation is not for HNAV !!! But for HN+.
Thanks a lot, I have MMI 3g plus so I think is ok.
By the way, to activate maps, when I get THE NAVIGATION DATA IS BLOCKED, all I have to do is to put de SD card in the slot 1 and the scrip does it, right?
ok cause the first picture shows that this is a Mmi 3g HNAV ?!?!
If you are sure tou ve HN+ (it must be written in the version menu), then yes to activate you only need to insert sd card with vslaoff activation on it (formatted in FAT32 before).
1 - 6 of 6 Posts
