1 - 7 of 7 Posts
Hello, I have an Audi Q7 2012 with MMI 3G Basic Navigation, I've done some updates : K0031-K0257 everything was ok but when I updated to K0260 it showed me an error ( some file was corrupted from sd card ). I've done an hard reboot and now it shows only an orange screen with this error:
Code:
MMI3G EmApp 22.27.1642
MU9303
Trigger shutdown in x sec!
Mount error
I found something on internet that I can do an emergency flash.
Can anybody help me to reflash my MMI3G navigation?
The navigation doesn't start, I can't enter into engineering mode again.
I will try tomorrow to enable green menu with vcds and do an emergency update or there is another way ?
Make a new good K0260 SD
Insert in the same slot you used before that.
Start the unit, it will go in emergency (that red screen) but this time it should be able to continue.
[QUOTE = "dfani511, post: 1485394, član: 107482"]
Pozdrav, imam Audi Q7 2012 s MMI 3G Basic Navigation, obavio sam neka ažuriranja: K0031-K0257 sve je bilo u redu, ali kad sam se ažurirao na K0260 pokazao mi je grešku (neka datoteka je oštećena sa sd kartice). Napravio sam težak ponovno podizanje sustava, a sada pokazuje samo narančasti zaslon s ovom pogreškom:
[KOD] MMI3G EmApp 22.27.1642
MU9303
Isključivanje u x sekundi!
Pogreška pri montiranju [/ CODE]
Na Internetu sam našao nešto zbog čega bih mogao obaviti bljesak.
Može li mi netko pomoći da promijenim svoj MMI3G navigaciju?
[/CITAT]Is your problem solved because I have the same situation?
1 - 7 of 7 Posts
