Please, check the link. I speak about last maps (2023, not 2022)what are not available? mega link are working
you download it MMI 3G Basic navigation 5.35.2 and firmware updates -...
Sorry congo for the question. The DBInfo shows this:ook ... will see that next week.
New upload made, password protected so cant be scanned from mega bot
Enjoy
Updated direclty to k260Hello
Bnav system P0022 actual fw
To use the latest map is obligatory to update firmware first ?
I've ordered vagcom, it does the same functions?[/QUOTE]hola,
you can also use the obdeleven or other dongle with your handy NextGen OBDeleven dispositivo
You could still try to install a current MMI update, but I almost think there is a hardware error.
wich firmware are on it, use the red menu to read it
Thank you for your help, I will try to install the new firmwareI have OBD11 Pro the red one and it is enough for quick vehicle checks/errors and coding
for me it does the same as vcds(has more text+help+users overall) and obd11 with my android tablet or mobile it is very flexible
If it's not the head unit, a fault in the MOST bus could be the cause at some point (interruption, for example).
Seek professional help, don't tinker around yourself.
That rarely helped.
As a layman, you can't do more than an MMI reset anyway.
Apologies, thank you for responding fast!Please read post 1.
If you are trying to install K0900 this is likely from a different MMI variant. Do not mix firmware it will not end well.
