561 - 580 of 1,462 Posts
I finally decided to go for it...
I followed Congo's manual... it has some differences from what I have saw, maybe because some things changed since 2016 not sure...
updated from BNAV_EU_K0206_2_D1 to BNAV_EU_K0260_1_D1
and GPS from 2011 4G0919884J ECE 5.12.4 TO 2018 4G0060884AC EUW 5.26.2
2018 activator worked it seams perfect
All seams to work ok
Since I don't have Vag.com I didn't clear errors yet... so Many tks to Congo and all that helped
I do have a question that if someone can help me I would appreciate... I have a Friend with a A5 with software version 3G_DAB_K0098 what version of firmware should he use to update before 2018 maps???
Best regards
Hi
I'm new on the forum , please somebody can tell me where (in wich file) the languages file are included , on the West and East 2018 map file or on the firmware 260 ?
thanks a lot
Mine says the same for software version. Currently on 2011 maps (8R0060884N ECE 5.12.5) so hoping there's an answer :)
Also, the megaupload link on page 1 is down...
I have all firmware and all maps..
just unsure if with that version I can update his version to the last BNav_EU_K0260_1_D1....
from what I could understand he needs the green menu to unselect BOSE and B&O .... before any update....
if you find an answer please let me know :)
tks
Turns out I dont have 3G Basic but 3G High (2011 sportback, pre-facelift) So i'm currently going through the steps in the other thread titled "MMI 3G navigation 6.28.2 Europe - currently 2019 "
Hey
I'm a bit unfamiliar with the A5 ( I currently have a A4) can you please PM how you did that assessment so I can try to help my friend too?
Help with map update
Folks,
I have bnv 5.24.2 2017 maps on my 2011 Audi A5 which I updated last year. Seen as there was a new 2018 map update I tried the update. So downloaded the 2018 maps put on an sd card to put on car, put SD card in and new database eur 2018 screen comes up so hit yes and then wait 30 seconds late i get the message that no update is present. what am I doing wrong? have I done something really stupid or do already have I the latest version.
Paddy
Hey
I have HDD navigation, and it's pre-facelift, so it's 3G HIGH. If it had DVD nav then it'd be 3G Basic
HDD nav on a facelift would be 3G+/3GP/3g Plus
Sorry I have also An audi A4 but the system must be the same.
I have a MMI 3G Basic with the K0260.
I m trying to install the map of 2018.
But nothing work. eject and insert SD card
my Nav work a little bit but after a short time it stop and tell that the version is not the good one
edit : sorry not the good one but no activated
edit2 : it's ok with the script
happy
I was told that it only works with one 2019 map. When you want to use the other map you have to uninstall the script and install the other map en install the script again.
that's really important to know... so I installed 2018 maps 2 months ago in that case I only need to put in the SD with the 2019 maps?
and is there a place where the script removal is? I couldn't find it... or running a new script overwrites the previous one?
Hello Congo and All,
I have just gone through the process of updating 2018 DVD2 West to the 2019 DVD2 West. This was activated via the script originally for 2018 and always used DVD2 West for the UK. The update did not complete and now I am stuck with 'Checking Medium'. I have done some searching and just wanted to check the process of recovery.
1 - Remove script activation with script removal
2 - Install 2018 FSC
3 - Put original 2018 sd card in slot and wait for not activated message
4 - Re-activate with the script
Or
Have you heard of this problem and know of a way to recover 2019 maps or is there another process to get working?
