did you install the software yourself or did you get it with your car? yes, the activator will workHello, I have the firmware BNav_EU_P0263_D1 and my question is if the activator works on this firmware. Thank you very much
Hi, sorry for disturbing you. I have your same problem. I have updated firmware to k0260, then 5.33.2 east. Now the 5.33.2 west is loaded but the system shows " no update found", even if I try to force the update via the engineering menu it is not working.Hi everyone !
I got MMI 3G Basic with software BNav_EU_K0260_1_D1
I'm after updating nav database from version 5.31.2 to 5.33.2.
The update went smoothly. I copied the files to the SD card. After inserting the card into the slot, it was detected automatically. GREAT ! I had to unlock the maps, i used a script for that. The navigation works great. I have the WEST version installed.
Now I have a little problem. I currently live in the Netherlands, but i want to go to Poland. When changing the card to EAST, the system does not detect any files. The downgrade and reinstallation 5.33.2 EAST is working. It's a bit hard. Does anyone know any other method?
I'm also thinking about unpacking the EAST and WEST archives to one SD card with the replacement of the same files.
Has anyone tried this before?
You already installed 5.33.2, and the system will not recognize the installation if it is already installed,you must wait for the next update to come, so that's my opinion... i hope i helped youHi, sorry for disturbing you. I have your same problem. I have updated firmware to k0260, then 5.33.2 east. Now the 5.33.2 west is loaded but the system shows " no update found", even if I try to force the update via the engineering menu it is not working.
I have also made an MMI emergency update and reinstalled everything with the same results.
Can you tell me how you managed to get it work ( from east to west and viceversa) even if it is a long procedure?
This doesn't explai why for previous updates you could use both maps ( east and west) with no problems.You already installed 5.33.2, and the system will not recognize the installation if it is already installed,you must wait for the next update to come, so that's my opinion... i hope i helped you![]()
Have someone tested this and can confirm what has been said?I think you have to be abroad for the maps to update. I had original maps on CD and the message "no update" was displayed. When I entered Germany, the update was found after inserting a specific map cd
You already have the answerNo one can help'?
Hello. I have a problem... when downloading the maps, the text says that DVD1 is Eastern Europe and DVD2 is Western.New map links updated in first page.
Enjoy
You are the best ... tnx a lotNew map links updated in first page.
Enjoy
From which country are you from ?Hello. I have a problem... when downloading the maps, the text says that DVD1 is Eastern Europe and DVD2 is Western.
When I go to Mega, when I want to download maps, it says DVD1 West and DVD2 East.
Which should I download for Eastern Europe?
Finally I ve updated firm included and all is running perfectly. Thanks CongoHello
I have BNav_EU_P0260_1_D1 , Do I have to update the firmware or there is no need? Can I only update the maps and activate them later or the activation won t work properly if I do not update the firm before?
Thanks in advance
