can you get my the p261 update file?Anyone, i have firmware version Bnav_EU_P0261_D1 my audi is from 2015 will this activator work ? i have now version 2015 map.
Do you have new bnav update ?See also the firmware update collection over at mega.nz.
Where did you get the 263 update file?No one knows?
Yes you can.I do not have an SD card slot on my PC. Can I use a USB to SD card adaptor to create my own activation SD card?
Thanks John. I cannot get the activator supplied with my new firmware and maps to work so might try to make my own.Yes you can.
The activator must be the only SD card in the unit.do I have to remove the SD card I have downloaded the maps from before using the activator SD card as with both cards in place I just get "release info cannot be read" then a prompt to abort?
Is this when using the engineering menu where I get "release info cannot be read" or for when you wait for "Nav info blocked" then insert SD card. I also saw a post where someone had to empty their 6 x CD changer before it would work. Have to say I am confused.com at the moment.The activator must be the only SD card in the unit.
As I purchased the Firmware/maps/activator set I don't know which type of activator I have got.Is this when using the engineering menu where I get "release info cannot be read" or for when you wait for "Nav info blocked" then insert SD card. I also saw a post where someone had to empty their 6 x CD changer before it would work. Have to say I am confused.com at the moment.
Hi Luke. Latest maps are 4G0060884AK and firmware needs to be K0260. I have just done mine with an SD card update set from the Satnavishop. I believe that you can make your own cards but I don't know how to do it that way and did not want to risk bricking the MMI. Only problem I had was activating the maps which was me not doing it the correct way. Hope this helps.hello team ... does anyone have any information about the new update for 3G BNav in 2022. ??
i know about 5.33.2 ..iam using it to, but that version is 2021/2022.... I wonder if there is any information on when the new update for 2022 will be releasedHi Luke. Latest maps are 4G0060884AK and firmware needs to be K0260. I have just done mine with an SD card update set from the Satnavishop. I believe that you can make your own cards but I don't know how to do it that way and did not want to risk bricking the MMI. Only problem I had was activating the maps which was me not doing it the correct way. Hope this helps.
As far as I know the new versions come out around December. I think the AK maps came out in Dec 21 and were called 21/22 maps. I guess they will never be right up to date like Google maps because of the time it takes to do them.i know about 5.33.2 ..iam using it to, but that version is 2021/2022.... I wonder if there is any information on when the new update for 2022 will be released
I think that the 21/22 update came out sometime in the summer, more precisely I think it was August or September, because I have had the 2021/22 update in use in my car for a long time.As far as I know the new versions come out around December. I think the AK maps came out in Dec 21 and were called 21/22 maps. I guess they will never be right up to date like Google maps because of the time it takes to do them.
You could be right there but the latest I have seen for sale are the AK ones. People on Ebay still selling the AH version and claiming them to be the latest but there has been the AJ and now the AK since. I was running 2017/2018 maps which my local Audi garage did for me and cost around £250 just for the maps. God knows what they would have wanted for the AK's which needed the firmware taking from P0022 to K0260 as well as the map update. The £55-99p I spent pales into insignificance in comparison.I think that the 21/22 update came out sometime in the summer, more precisely I think it was August or September, because I have had the 2021/22 update in use in my car for a long time.
I read on the internet that there is a version 4G0 060 884 AL or 5.34 2022 edition .... but it is nowhere to be foundYou could be right there but the latest I have seen for sale are the AK ones. People on Ebay still selling the AH version and claiming them to be the latest but there has been the AJ and now the AK since. I was running 2017/2018 maps which my local Audi garage did for me and cost around £250 just for the maps. God knows what they would have wanted for the AK's which needed the firmware taking from P0022 to K0260 as well as the map update. The £55-99p I spent pales into insignificance in comparison.
