941 - 960 of 1010 Posts
Administrator
Audi A4 B8 MMI 3G Basic
I have a micro-sd but today i will buy a normal sd card
FAT32 card format files are fine on the card
Is it the fault of the SD card ?? Because I read that it may be the fault that the original DVD map was installed and now you need to remove the activator and FSC ???
micro-SD cards in an adapter often causes problems, but not always.
don't know about the installation of the original DVD.
but than again, all cars have the origininal DVD installed, from the start.
what is the model-year of yr A5 ?
did you use a full size SD-card or did you use a micro-SD with adapter ?
what is the size of the SD-card ?
how was the SD-card formatted ?
My model is from2011, it a full size SD -Card, size ist 512MB, it's a standard FAT Format
Everything looks like described by congo, but the process just don't starts when I press the start button
Administrator
the maximum size for MY2011 is 32 GB, so that is OK
it has to be an SDHC card en not XDSC
standard FAT for 512MB sounds normal to me
you might have to try another card.
are you using a Windows pc/laptop or something with macOS ?
MMI 3G Basic navigation 5.31.2 and firmware updates - currently 2020/2021
Map & activator:
MMI 3G Basic 5.31.2 Europe 2020/2021 [Link on Mega]
DVD1 East: Germany, Lichtenstein, Austria, Switzerland, Albania, Bosnia- Herzegovina, Bulgaria, Denmark, Estonia, Finland, Greece, Italy, Croatia, Corsica, Kosovo, Latvia, Lithuanian, Macedonia, Moldavia, Montenegro, Norway, Poland, Romania, Russia, San Marino, Sweden, Serbia, Slovakia, Slovenia, Czech Republic, Ukraine, Hungary, Vatican City, Belarus
DVD2 West : Germany, Lichtenstein, Austria, Switzerland, Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain
Firmware:
MMI 3G BASIC A4-A5-Q5-A6-Q7 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 AA – BNav_EU_K0031_2_D1 (SVM: 3GBEU031)
• 8R0 906 961 AH – BNav_EU_K0070_2_D1 (SVM: 3GBEU070)
• 8R0 906 961 BD – BNav_EU_K0206_2_D1 (SVM: 3GBEU206)
• 8R0 906 961 AL – 3G_DAB_K0098 (SVM: 3GRU0098)
• 8R0 906 961 BC – BTHS_0400
Manual:
3G_BASIC.pdf [Link on cloud.mail.ru || Link on Mega]
Q&A section
A. Not for now.
Q. I have mmi 3g , version p0XXX can i go straight to k0260?
A. Yes.
skipMetaCRC = "true"
Cheers :wink2:
Hello
I need please the last way to make map Update
I finally found the Problem with sd card
Now the System find the sd card but if i select yes (Foto) its told me there are no Update avilable!
What can i Do
181242
181243
181244
Map & activator:
Firmware:
Manual:
Q&A section
A. Not for now.
A. Yes.
Cheers :wink2:
Should i copy the DVD 1 and 2 both in the sd card
Or just the first???
I have puted only the first 1?
Its that correct?
Thank you
you should only one DVD on an SD-card
if you need both DVD's, you will need 2 SD-cards
181245
181246
Thanx alot for your reply
What can i Do
Hi
I looked at the forum but I did not find the answer to my question.
I am in BNav_EU_P0262_D1 firmware.
Should I update to K260 or just install the new card and activate (my firmware seems newer than the K260 and I have a bang and olufsen system)
I tried another SDHC Card (from windows PC), but the problem i still the same: after hitting "Start" - nothing starts... I cant only "abort" after some time (minutes till hours)
I tried installing the 5.32.2 card. directly on firmware p0262_d1. Everything works correctly I just had to do a forced reboot after installing the activator (setup + central button + right button) Installation of the map in sd port 1 then after having received the message map not activated, install the activator in sd port 2 I hope this helps someone !
Vehicle Automotive design Personal luxury car Gas Multimedia
Hi, I would like to update my maps contents, but after download the .rar file Wesr or East (it doesen't matter) from Mega, I got message "broken .rar file".I try many times download and I try it on Windows 10 with winrar, TotalCommander. Is there any another way to download both West and East files?
Can someone please reupload it to another server?
My next questions:
1. after reading forums I came to a conclusion that this is for my BNav_EU_P0260_D1 right update. Can you please confirm that?
Technology Font Vehicle Multimedia Display device
2. Is necessary upgrade the firmware too?
3. Is possible to copy content from both rar files to one SD card?
4. Activator must be on same SD card? If yes, before or after update maps?
Thank you tor your answer. Ofcourse I read first page of this topic and pdf manual, I just wanted to make sure that this update is the right one :)
So, I try again download both rar files right now, but again a got message with broken files :( Please is there anyone who can reupload these files?
Thanks for your link, finally I update my map content :) The problem was in my rar archiver. I reinstal 7zip and now all working like charm (ofcourse link from first page at this topic too) Thank you and I go planing my route :D
I think Map works with P0260 ( Map working on p0257 and p0262 so i think works on p0260)
Try this link 7.95 GB folder on MEGA.
( New Map 2021 ) , i have unzip it with last 7zip
1) install New Map on SD slot number 1
2 ) When Map is installed put activator in SD slot number 2 and then install it
Hello!
Can you please help me one more time, because I'm reading on forums how to update navigation for 3 days, and I still don't understand the correct procedure. I have BNav_EU_P0206_D1 and the database 4G0919884K ECE 5.13.8 and all of the content of navigation is on a SD card in slot 2 (when take out the SD card then I have no navigation and I get the message to put in a media).
So for one more time can you explaind the exact steps what i should do in my case, bacause everybody is talking about the first page and the activator, but you only have 2 steps and also an activator in your mega download folder?
I bought the car about 3 weeks ago and I the the previous owner did not ever upgrade the maps. All I know is that the car has no HDD, and that's another thing that confuses me about where do you install the map what you download?
Everything on the car is worling fine, no falut codes (via VCDS), so I don't want to mess up the whole unit.
Thnak you in advance.
