921 - 940 of 1010 Posts
MMI 3G Basic navigation 5.31.2 and firmware updates - currently 2020/2021
Map & activator:
MMI 3G Basic 5.31.2 Europe 2020/2021 [Link on Mega]
DVD1 East: Germany, Lichtenstein, Austria, Switzerland, Albania, Bosnia- Herzegovina, Bulgaria, Denmark, Estonia, Finland, Greece, Italy, Croatia, Corsica, Kosovo, Latvia, Lithuanian, Macedonia, Moldavia, Montenegro, Norway, Poland, Romania, Russia, San Marino, Sweden, Serbia, Slovakia, Slovenia, Czech Republic, Ukraine, Hungary, Vatican City, Belarus
DVD2 West : Germany, Lichtenstein, Austria, Switzerland, Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain
Firmware:
MMI 3G BASIC A4-A5-Q5-A6-Q7 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 AA – BNav_EU_K0031_2_D1 (SVM: 3GBEU031)
• 8R0 906 961 AH – BNav_EU_K0070_2_D1 (SVM: 3GBEU070)
• 8R0 906 961 BD – BNav_EU_K0206_2_D1 (SVM: 3GBEU206)
• 8R0 906 961 AL – 3G_DAB_K0098 (SVM: 3GRU0098)
• 8R0 906 961 BC – BTHS_0400
Manual:
3G_BASIC.pdf [Link on cloud.mail.ru || Link on Mega]
Q&A section
A. Not for now.
Q. I have mmi 3g , version p0XXX can i go straight to k0260?
A. Yes.
skipMetaCRC = "true"
Cheers :wink2:
Can you please help me,
collected a 2010 60 plate Audi A5 on Saturday
What do I need to get the sat nav working?
Map & activator:
Firmware:
Manual:
Q&A section
A. Not for now.
A. Yes.
Cheers :wink2:
Hi
can you help me please,
I collected a 2010 60reg Audi A5 on Saturday,
what do I need to make the sat nav work? A dvd or a sd card?
Any help is appreciated
181206
181207
Confirmation?
Hi Congo,
I've just found this thread while searching for firmware updates for my A6 Avant C6, which has MMI 3G Basic (Low).
All the indications here suggest that the firmware files you have posted are the same for my system as for the A5 but before I go ahead and start the update process, could you please offer any reassurance that I am correct in this assumption?
My biggest fear is that I'll brick the MMI!
Thanks in advance.
This is my system:
sorry does your sat nav use a dvd or sd, I collected a 2010 A5 on Saturday and the car is missing the dvd or sd card
181216
181217
After many hours of trying to get rid of the checking medium message using all the techniques given here I was about to give up.
But I thought I'd give it another try.
So I done an emergency update on the green menu using the current K0260 firmware.
Then I put the sd card with the 2020/21 map in sd1 slot, again it said checking medium.
This time I went into the red engineering menu and saw the map software shown on the screen and clicked and updated it.
After exiting and rebooting, the map started and I didn't need a script to activate.
I found The instructions are similar to what I done in the write up on this Web page so follow them and you should be OK.
https://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=7745
It may be possible to do this without doing the emergency update. so maybe try it without the emergency update and just go into the red menu and update first and see if it solves the checking medium problem. Hope this sorts out your problem.
I still have the problem updateing my Audi A5 Train Version K0070 to K0260.
I prepared SD cards as described by congo. I followed his instructions.
My problem is when I choose after all necessary steps "Start update" I the get the screen with "Start" and "Abort", I pressed Start and waited but nothing happened ? No Reboot, the next screen "Update progress" did not came, No download...
I assume the process is not starting
The only chance was to abort the update. The logging menu showed the tried update, but with NOK.
Did I make something wrong or forgot something? Any workaround? Please help me :)
Administrator
what is the model-year of yr A5 ?
did you use a full size SD-card or did you use a micro-SD with adapter ?
what is the size of the SD-card ?
how was the SD-card formatted ?
Audi A4 B8 MMI 3G Basic
I have a micro-sd but today i will buy a normal sd card
FAT32 card format files are fine on the card
Is it the fault of the SD card ?? Because I read that it may be the fault that the original DVD map was installed and now you need to remove the activator and FSC ???
