841 - 851 of 851 Posts
Insérez la carte SD avec le micrologiciel approprié pour votre MMI!
Quel MMI avez-vous? 3G de base / 3G haut / 3G +?
Hello Jordy, my MMI is 3G Basic // BNav_EU_? / Harman / Becker
Without hard disc / Euro card reading from DVD / With 6 CD player in glove box / Radio tuner in the rear trunk.
Best regards.
Alex78
Download firmware K0260 and copy the contents of a SD card. MMI will automaticly resume firmware installation.
MMI 3G Basic navigation 5.31.2 and firmware updates - currently 2020/2021
Map & activator:
MMI 3G Basic 5.31.2 Europe 2020/2021 [Link on Mega]
DVD1 East: Germany, Lichtenstein, Austria, Switzerland, Albania, Bosnia- Herzegovina, Bulgaria, Denmark, Estonia, Finland, Greece, Italy, Croatia, Corsica, Kosovo, Latvia, Lithuanian, Macedonia, Moldavia, Montenegro, Norway, Poland, Romania, Russia, San Marino, Sweden, Serbia, Slovakia, Slovenia, Czech Republic, Ukraine, Hungary, Vatican City, Belarus
DVD2 West : Germany, Lichtenstein, Austria, Switzerland, Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain
Firmware:
MMI 3G BASIC A4-A5-Q5-A6-Q7 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 AA – BNav_EU_K0031_2_D1 (SVM: 3GBEU031)
• 8R0 906 961 AH – BNav_EU_K0070_2_D1 (SVM: 3GBEU070)
• 8R0 906 961 BD – BNav_EU_K0206_2_D1 (SVM: 3GBEU206)
• 8R0 906 961 AL – 3G_DAB_K0098 (SVM: 3GRU0098)
• 8R0 906 961 BC – BTHS_0400
Manual:
3G_BASIC.pdf [Link on cloud.mail.ru || Link on Mega]
Q&A section
A. Not for now.
Q. I have mmi 3g , version p0XXX can i go straight to k0260?
A. Yes.
skipMetaCRC = "true"
Cheers :wink2:
Dear friend thank you for your sharing
I downloaded all... but East Map Dvd doesnt open with winrar. There is some file problem. west part is ok. could you refresh "East Dvd" file please.(I downloaded 3 time but same problem)
Hi boys maybe this it's stupid question but I prefer to be sure, I done everything update my mmi update my maps and I put on my SD card West maps can you keep them together on same SD card West and East or they need to be separated on two SD? Thanks for replying.
Nope, one sd for west and one sd for east.
I have a 2015 S5 with BO. From what I read so far I have to avoid updating the BO system. Just to confirm I either to that by script or I get a bypass loop device?
Hi. 3G Basic here, A6 Lemans C6. Firmware updated no probs, maps, different thing. Copied all files to SD and tried to update, it initially sees it, but when going to update it says no update/media found. Obviously doing something daft! Should I just copy them (west and activator) as folders?
Heres a link to a video on dropbox
