781 - 800 of 808 Posts
Moderator
Thanks, got it. I downloaded all files, on firmware I have 2 folders, one for firmware and other one is iso and zip file, what to do with that files?
Hello,
could someone upload 5.30.2 maps, because previous link in no longer available? Also, i would like to tell that you can install 5.28.2 maps on k257 firmware without any problems.
Hi everybody.
First of all, thank for all the people doing a great job here.
I have a problem with my software version, mine is BNav_EU_P0261_D1. I Have been reading a lot how to update, but if I need K0260 I think I need to downgrade it.
Is there any safe method to do this?
My map version is 4G0919884R EUW 5.21.2
I have found some information about this firmware in forums from Russia, Italy and other countries, even in this forum, but I haven´t found any response, so I think that´s not a usual firmware.
So, the question is wether installing any firmware, the update overwrites the previous firmware, regardless if it´s older or newer. I think it's easier for someone to have happened this in one of the previous updates, with other firmwares.
thanks in advance
hello, downloaded the FW link in the first post. but there is missing K0257. there is only K0260 and SDS audio CD. can somebody provide the K0257? thx
[QUOTE = "Elmo299, publicación: 1614497, miembro: 125014"]
¿Alguien tiene un enlace a los mapas de la versión 2021 audi maps 5.31.2, 4G0060884AH?
[/ CITAR]
Eliminado por no adecuarse a las reglas del foro.
Hi everyone, I'm trying to update my MMI 3G Basic, currently is this firmware:
179239
I have update to 5.31.2 (2021 maps), and I don't know what, but something I do wrong. The first thing I notice after update is that in "navigation version" there isn't nothing, is that normal?
After that, I extract the SD in slot 1, and insert in #2 the activator called "Audi_3GB_Fix_K0260", of course previously formatted in Windows with "SD formatter" in FAT32, 20" after, the script says press any key, and everything is ok, press any key again, and extract SD #2. I reset the MMI, and insert SD #1 (maps) and:
179240
This is the end, my navi doesn't exit that screen...
So searching solution, I have find that I have to delete the previous FSC script, so I do that in other SD with:
FSC Removal
Russian hacktivation tool
Activator Uninstaller
Yes, all of them, in different moments after checking the navi does not charge.
I have no idea what I'm doing bad... any help?
Thanks.
I can see that on one another forum they have MMI 3G BASIC 5.31.2. Anyone has that one (2020 version)?
Audi MMI 3G Basic (BNav) 5.31.2 - 4G0060884AH Europe Maps 2020–2021
For those users using Usenet for downloading the 2020-2021maps, firmware K0260, the Activator and the 'how to' manual, attached the link to the nzb file:
pass=Tigers
size=12,79GB
