721 - 740 of 752 Posts
MMI 3G Basic navigation 5.28.2 and firmware updates - currently 2019
New 2019 Activator
No FSC at the moment
Map & activator:
4G0060884AE (MMI 3G Basic Europe 2019 DVD) [Link on Mega]
DVD1 East: Germany, Lichtenstein, Austria, Switzerland, Albania, Bosnia- Herzegovina, Bulgaria, Denmark, Estonia, Finland, Greece, Italy, Croatia, Corsica, Kosovo, Latvia, Lithuanian, Macedonia, Moldavia, Montenegro, Norway, Poland, Romania, Russia, San Marino, Sweden, Serbia, Slovakia, Slovenia, Czech Republic, Ukraine, Hungary, Vatican City, Belarus
DVD2 West : Germany, Lichtenstein, Austria, Switzerland, Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain
Firmware:
MMI 3G BASIC A4-A5-Q5-A6-Q7 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 AA – BNav_EU_K0031_2_D1 (SVM: 3GBEU031)
• 8R0 906 961 AH – BNav_EU_K0070_2_D1 (SVM: 3GBEU070)
• 8R0 906 961 BD – BNav_EU_K0206_2_D1 (SVM: 3GBEU206)
• 8R0 906 961 AL – 3G_DAB_K0098 (SVM: 3GRU0098)
• 8R0 906 961 BC – BTHS_0400
Manual:
3G_BASIC.pdf [Link on cloud.mail.ru || Link on Mega]
Q&A section
A. Not for now.
Q. I have mmi 3g , version p0XXX can i go straight to k0260?
A. Yes.
skipMetaCRC = "true"
Cheers :wink2:
Recovery of "bricked" MMI 3G units - 3G Basic (DVD-Rom;7T2), MMI 3G/3G+ (HD;7T6), RNS850
MMI 3GP K0900 MAP 2016, MMI 3G HIGH K0257 MAP 2016, MMI 3G BASIC K0260 MAP 2016, MMI 2G HIGH 5570 MAP 2016
Coding of STG 46 Halogen to LED tail lights A4/8K A5/8T A6/C7 A7/4G || Turning off start-stop system
Google Earth/Sreet View on RNS850
On which link can I download the activator for MMI 3g basic 2019 maps
ja tentei o medidor ou o segundo SD com o ativador mas fica bloqueado na mesma. funciona durante alguns segundos e depois aparece base de dados bloqueados. o que fazer agora? alguém me pode ajudar?
O que outras pessoas estão dizendo
the general language on this forum is English.
may be you could make the effort and try again.
I already tried the meter or the second SD with the activator but it is still blocked. it works for a few seconds and then a blocked database appears. What to do now? someone can help me? What others are sayingSee more
Help me with a tip: Audi 2011 Bnav P0054 - firmware update to K0070 after which it does not recognize either 257 or 260. With none of the 3 cards - nor with the one with which I made the update of K0070. What am i doing wrong?
Thank you in advance.
Could it be so, that Audi A5 2010 with 3G basic: bnav_eu_p0022_d1 doesn’t have any HDD?
Can that be easily check from green menu or somewhere else?
Nav database version is not showing anything, when checking MMI version.
Car has at-least SD1 & SD2 slots and DVD
If there’s really no HDD, can it still use same maps than version that has HDD and 3G basic?
Or does without HDD version, need different maps / DVD maps?
that is correct, so no HDD
no, different maps
I suggest you go through this topic, starting at post number ONE.
and read the installation instructions, as well
Hi everyone,
I have literally read all the instructions/comments.I managed to update the firmware succesfully using usb cable and usb stick.I have purchased 2 sdhc cards 8 gb for the map updates and the activaton.My problem is i have done everything according to instructions however when i put the sd card in sd 1 slot OR 2, map update doesnt automaticlly starts like it says in the instructions but when i put activator in, it recognizes straight away.Copied files in the root of the sd,its formatted to FAT32.If i open engineering menu ,i can see that files are there but it doesnt update the maps!could this be because map were never updated?Firmware wasnt so i just thought i ask.Can i update it straight to 2019 west europe?
software was =Bnav_EU_P0O22_D1 now BNAV_EU_KO260_1_D1
Nav Database version is 4G0919884F_ECE 5.10.5
Hi all,
First off all thanks for a great work and effort . I manage to update firmware to BNAV_EU_KO260_1_D1and 2019 maps, however I can't activate it. I've try activator for 2020 map from page 35, it's looks like is only available at the moment, unfortunately nothing is happening when I push sd card in slot 1 (maps in slot 2). I unzip it and copy all content to root of sd card but no luck, can I have same help please? Thanks
Regards
Dan
Looking for some help, I have upgraded from factory BNav_EU_P0022_D1 to K0260 and also installed the latest BNav West Map from this thread. I need to activate this map but I think I'm missing something. It says the Activator is included in the download for "4G0060884AE (MMI 3G Basic Europe 2019 DVD)" which I have installed on SD 1 and is working fine but coming up blocked after 5 minutes. Can someone confirm what files within this download I need to put on a secondary SD 2 to run the script and run the activator? Apologises if this is a n00bish question, this is all new to me (took me 4 hours to get this far lol).
Hello, I have a 64g sd card and I have maps on it, can I insert mp3 music next to the map on the same card? Thanks
New 2019 Activator
Map & activator:
Firmware:
Manual:
Q&A section
A. Not for now.
A. Yes.
Cheers :wink2:
Excuse me but i dont found the activator in link... Its normal ?
I need to fond them rapidly.
Thx for all.
Sorry for my shit english ^^
Hello Congo. I have installed firmware update 260 and maps 2020 and 2019 and I cannot activate them. The cativador is (Vlasoff maps activation). It tells me the maps are not activated and the activator fails when trying to run it. Might you help me?
Thanks a lot @bpodnar This message from you save my life!!
MMI already updated and working on K0260 and 2019 West maps
One beer for you, is waiting is Spain!!
No, you dont have to downgrade from 2018. First make sure that you're on K0260 and you must know which Activator is used FSC or Script. If FSC activator is installed then I recommend to remove it with FSC removal script FSC Removal (extract it to sd card root, put ignition on, insert sd card to slot 1). Dont worry about images in script they are in 800x480 resolution so they will override your mmi screen resolution. After you removed FSC Activator insert sd card with 2019 maps turn on Map view and wait for message about blocked maps for 2 minutes approx. Then insert sd card with Audi_3gb_fix-K0260 script Activator Audi_3GB_Fix_K0260 and follow the instructions on mmi screen. After script is applied reboot mmi and you are good to go. If you want to use second 2019 map you have to install 2017 map first (east or West) and then install 2019 you want. When reversing back to primary 2019 map the procedure is always the same 2019>2017>2019
Here is link for 2017 east map dvd2 2017 3gbasic.torrent
