Im clueless at this where do you find the 942 version?Welcome. Perhaps you would like to read the first post where the firmware details are provided? You will find version 942 is the latest.
These maps are possible install on a RNS850 P0824 with South Africa maps??Yes,
here is the map link (thanks Byront for that)
And here is prepared fixes:![]()
ANZ 3G+ - 412.3 KB file on MEGA
ME 3G+ (untested yet) 412.4 KB file on MEGA
SA 3GHigh - 412.4 KB file on MEGA
SA 3G+ - 412.4 KB file on MEGA
Install the map, use the activator from very first post and then use the fix provided here.
Enjoy your new map.
Fixes for other parts of the map will be provided on demand
Hi is this for HNAV MMI 3GHNav alone -> 63.17 GB folder on MEGA 3G+ alone -> 63.17 GB folder on MEGA Activation and other things - the same as before.
You're running MMI version P0662; in post #1, you'll see the lastest [and final] version for your vehicle is K0942. If you have a Bose or B&O amp, you might like to consider downloading the 'Modified Firmware' version as it has been suggested these amps may be affected [needing a dealer intervention] if they are updated.The MMI version information:
Media version: HN+_EU_AU3G_P0662
Nav. database version:
8R0060884BC ECE 6.16.3
I will be very helpful if anyone can advise me which version I need to use to upgrade to latest version of firmware and the maps?..
Thanks you very much for the advise I will take a look into also will take your advise in consideration for using modified firmware.You're running MMI version P0662; in post #1, you'll see the lastest [and final] version for your vehicle is K0942. If you have a Bose or B&O amp, you might like to consider downloading the 'Modified Firmware' version as it has been suggested these amps may be affected [needing a dealer intervention] if they are updated. You're running the 2013/2014 version of the ECE [European] maps. The 6.33.1 maps would be my suggestion; the 6.34.1 maps are unavailable and there are potential issues with the 6.35.1 maps.
Sorry to disturb you again with more question, as you had mention I can use K0942 version for my Audi A4 and need to consider for using Modified Firmware? is there any different in both version ? or can I stick with • HN+_EU_AU3G_K_0900 - Stock firmware ? without affection my amp. I don't know if it Bose or B&O soundsystem I haveYou're running MMI version P0662; in post #1, you'll see the lastest [and final] version for your vehicle is K0942. If you have a Bose or B&O amp, you might like to consider downloading the 'Modified Firmware' version as it has been suggested these amps may be affected [needing a dealer intervention] if they are updated.
hi i need for audi a1 rmc eu p11474MMI 3G+/3GP navigation 6.35.1 and firmware updates - currently 2022/2023 Europe
Its time for a new thread and i hope this one will be kept clean
Here is a link to the old one, please check there before asking questions that might have already been answered in the past.
Maps & activator:
Europe
6.35.1 2022/2023 MMI 3G High/Plus Europe [Link on Mega (use 7z/7zip to open the files)]
6.34.1 2022 MMI 3G High/Plus Europe [Link on Mega (use 7z/7zip to open the files)] Password: 8R0051884JN
6.33.1 2021/2022 MMI 3G High/Plus Europe [Link on Mega (use 7z/7zip to open the files)] Password: 8R0051884JD
6.32.1 2021 MMI 3G High/Plus Europe [Link on Mega (use 7z/7zip to open the files)] Password: 8R0051884HQ
Rest of World
5.13.4 2021 MMI 3G High/Plus ROW - ANZ,SA,ME,HN,SM ... here!
NAR
6.20.1 2019/2020 MMI 3G ... here! If it asks for password then use this one -> 8R0060884GJ
Activator [Link on cloud.mail.ru || Link on Mega]
Firmware:
Audi A1 [Link on cloud.mail.ru || Link on Mega]
• 8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Audi A4-A5-Q5-Q7
• HN+_EU_AU3G_K_0942 - Stock firmware
• HN+_EU_AU3G_K_0900 Modified firmware - User Defined Mode / No Sound systems
• HN+_EU_AU3G_K_0942 Modified firmware - User Defined Mode / No Sound systems
Audi Q3-A6-A7-A8
• HN+R_EU_AU_K0900 - Stock firmware
• HN+R_EU_AU_K0942 - Stock firmware
• HN+R_EU_AU_K1001 - Stock firmware
• HN+R_EU_AU_K0900 Modified firmware - User Defined Mode / No Sound systems
• HN+R_EU_AU_K0942 Modified firmware - User Defined Mode / No Sound systems
Manual:
3G_3GP.pdf [Link on Mega || Spanish translation thanks to homarc || 2017 MAP Update thanks to homarc]
How to user 64GB SD card [Link on Mega]
These are the required files and folders for Map 6.33.1 with 32GB SD card. Thanks to @JulianHicks for creating the lists.
See "3GP_Filelist.txt" (3GP) and "3GH_Filelist.txt" (3G High) attachments in this post.
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
Warning - FW update K0900 is removing the "Emergency Update" option from the "Green Menu". There is a way that this can be fixed.
• Emergency menu activation on K0900 firmware. [ Only for A5OC ]
• To enable the Green Menu you could use VCDS, VAS or the following script [ Green menu activation ]
• 03623 [ 03623 Remove ]
- Unzip it on the SD card.
- Put the sd card in the MMI.
- When prompted press the center knob.
- After the script is done you will see confirmation screen.
- Remove the SD card and reboot MMI
Do not use MAC to unpack and/or copy the files to the SD card.
Q&A section
A. Not for now.
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
Q. Have found the activation script and it includes "2380_00040009.fsc". This should be changed according to manual Page 31 to the MAC address specifically to my MMI or should I continue to use the "2380_00040009.fsc" as stated in the manual page 18.
A. Leave the filename as it is now.
Q. The 2380_00040009.fsc file contains a VIN number. Should that be changed to my VIN number?
A. No, do not attempt the edit the fsc file.
Q. Will my VIN be visible and correct in the MMI
A. Yes.
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Q. What does the new firmware bring in terms of added functionality?
A. Not much, apart from K0770/K0767 fixing the issues with the SIM data connection and Bluetooth usage at the same time.
skipMetaCRC = "true"
Apologies; didn't get notified that you added this query!Sorry to disturb you again with more question, as you had mention I can use K0942 version for my Audi A4 and need to consider for using Modified Firmware? is there any different in both version ? or can I stick with • HN+_EU_AU3G_K_0900 - Stock firmware ? without affection my amp. I don't know if it Bose or B&O soundsystem I have
maybe thats:Hi all. I sourced all of the cards from a very well known Audi nav update person. Filled all instructions as listed starting with the firmware then maps and finally activation. All seemed to have gone well but I don't have any sound. Volume unavailable;DSP in sound settings no longer showing,bass,treble all set on min and unable to change. Fader/balance stuck in front left speaker and unable to move. Constantly loading media and devices. Can add Bluetooth, Sat nav works and I can copy CD to jukebox but no sound on anything. Contacted supplier who advised to try install of firmware again but go in to every folder and tick all boxes except bootloader boxes. Continued with install and it came up with ARU9440 no communication. Install continued without this but after install showed NOK in dab folder. Tried battery disconnection and unplugged dab tuner in left hand boot compartment but still no joy. Anything I could do to sort this would be appreciated. Ill upload screen pics of what went on.
