MMI 3G+/3GP navigation 6.36.0 and firmware updates - currently 2023 Europe
460730 Views 1730 Replies 351 Participants Last post by  DrGER
Its time for a new thread and i hope this one will be kept clean :)
Here is a link to the old one, please check there before asking questions that might have already been answered in the past.
Maps & activator:
Europe
6.36.0 2023 MMI 3G High/Plus Europe [Link on Mega (use 7z/7zip to open the files)]
Rest of World
5.13.4 2021 MMI 3G High/Plus ROW - ANZ,SA,ME,HN,SM ... here!
NAR
6.20.1 2019/2020 MMI 3G ... here! If it asks for password then use this one -> 8R0060884GJ
Activator [Link on Mega]
Firmware:
Audi A1 [Link on Mega]
8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Audi A4-A5-Q5-Q7
HN+_EU_AU3G_K_0900 - Stock firmware
HN+_EU_AU3G_K_0942 - Stock firmware
HN+_EU_AU3G_K_0900 Modified firmware - User Defined Mode / No Sound systems
HN+_EU_AU3G_K_0942 Modified firmware - User Defined Mode / No Sound systems
Audi Q3-A6-A7-A8
HN+R_EU_AU_K0900 - Stock firmware
HN+R_EU_AU_K0942 - Stock firmware
HN+R_EU_AU_P1001 - Stock firmware
HN+R_EU_AU_K0900 Modified firmware - User Defined Mode / No Sound systems
HN+R_EU_AU_K0942 Modified firmware - User Defined Mode / No Sound systems
Manual:
3G_3GP.pdf [Link on Mega || Spanish translation thanks to homarc || 2017 MAP Update thanks to homarc]
How to user 64GB SD card [Link on Mega]
These are the required files and folders for Map 6.33.1 with 32GB SD card. Thanks to @JulianHicks for creating the lists.
See "3GP_Filelist.txt" (3GP) and "3GH_Filelist.txt" (3G High) attachments in this post.
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
Warning - FW update K0900 is removing the "Emergency Update" option from the "Green Menu". There is a way that this can be fixed.
• Emergency menu activation on K0900 firmware. [ Only for A5OC ]
• To enable the Green Menu you could use VCDS, VAS or the following script [ Green menu activation ]
• 03623 [ 03623 Remove ]
  1. Unzip it on the SD card.
  2. Put the sd card in the MMI.
  3. When prompted press the center knob.
  4. After the script is done you will see confirmation screen.
  5. Remove the SD card and reboot MMI
Do not use MAC to unpack and/or copy the files to the SD card.
The problem:
I've tried to update my firmware (MMI 3G+) to K0767 and got the following error:
GEMMI_nav:0 error code 141
I could only access "Retry" choice (but update kept blocking at 5% with the same error) or "Back" button that was useless
Unable to do anything else, even the Reset procedure didn't work!
Root cause:
This is a file corruption error, the MMI didn't like what it found on the SD card.
Because I'm a stupid software engineer who thinks he knows best, I didn't trust the forums and copied the files from my mac onto the SD card (using command line to clean-up the .Trashes/ and alike folders)
So this is the lesson: DO NOT COPY FROM A MAC
Sub-lesson: better learn from other's mistakes than redo the experience...
Solution:
As stated previously, even a MMI reset procedure didn't allow me to get out of the error.
So I went to my neighbour's Windows PC, reformatted the SD card and extracted the RAR archive onto it.
Back to the car, update went fine and completed successfully after 30 minutes
Hope this experience will help some fellow here...
LESSONS LEARNED - NEVER USE MAC OS (or Unix, Linux based OS) for unpack and copy map or firmware data into SD card. Also always format SD card in Windows OS. USE ONLY WINDOWS FOR UNPACK/COPY!!!
I had to upgrade Firmware as well. I could not load map data even they were copied in windows. It means that also Firmware was corrupted.
I found cca 10 000 hidden files on Firmware SD card. Dangerous is that Firmware seemed to be OK all the time but it was not and I could destroy whole MMI
(Imagine that FPGA or EEPROM is burned with some hidden apple .bin file....).
Q&A section
A. Not for now.
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
Q. Have found the activation script and it includes "2380_00040009.fsc". This should be changed according to manual Page 31 to the MAC address specifically to my MMI or should I continue to use the "2380_00040009.fsc" as stated in the manual page 18.
A. Leave the filename as it is now.
Q. The 2380_00040009.fsc file contains a VIN number. Should that be changed to my VIN number?
A. No, do not attempt the edit the fsc file.
Q. Will my VIN be visible and correct in the MMI
A. Yes.
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Q. What does the new firmware bring in terms of added functionality?
A. Not much, apart from K0770/K0767 fixing the issues with the SIM data connection and Bluetooth usage at the same time.
skipMetaCRC = "true"
Reactions: 5
741 - 760 of 1731 Posts
@ccb : Better to show us the screen MENU > MMI Setup > Version information; it gives both software and nav database versions.
You write that you extracted to a "flash drive", above. Do you mean full size 32 GB SD card or USB thumb/flash drive connected to a AMI/USB cable? In either case, the device must be formatted as FAT32; and a high speed SD card is preferred here, although USB flash drives have been known to work. Post a screen shot of the Error 146 if you see it again. --g
Here's the requested screen:
Vehicle Motor vehicle Gadget Automotive design Font
In regards to the flash drive. Yes, I have gotten myself an adapter from AMI to USB and a 64gB flash drive formatted in exFAT.
FYI, the maps were extracted using the required password. There shouldn't be any problems there.
Audi Navigation doesn't have an ROW version; it publishes 9 versions, so you'd need to specifically quote the one you need.
[Europe, North America, Asia Pacific, Australasia, South America - inc India & Turkey, China, Japan, Korea, Taiwan]
However, this thread has never supplied anything other than the European version so you'd need to ask elsewhere.
Hello. I need a map of Turkey. This map is located inside the Row. He wrote that it will be shared soon in the section I quoted. I asked too. If you have can you share it with me? Thanks.
@ccb : The MMI 3G+ system does not have support for exFAT. These external storage media need to be reformatted as FAT32. The other complication here is that non-OE AMI/USB cables do not always work properly with storage devices (external & flash drives). Hence, full size SD cards are recommended typically for updates of this type. --g
Reactions: 1
Fair enough.
Could you confirm if everything else is done in the correct manner for me?
I will go get the memory card today.
Also... Could it be a microSD with an adaptor or does it have to be the big SD card instead?
Avoid microSD cards using a full-size adapter. The nav database update transfers many 2 GB files to the MMI hard disk, and you want to minimize the possibility that a faulty electrical connection will corrupt the data transfer; using a microSD card in an adapter only adds another point of failure. And once you've updated successfully, you can repurpose the SD card for music/audiobooks/whatever in SD slot 2. --g
Reactions: 1
Audi produces a map pack that includes some much smaller regions (Aus/NZ, Middle East 1 & 2, Singapore etc) - I have just literally managed to get my copy of 2021 maps to work in NZ - Congo supplied me a corrected activator to enable these, as there is not one working as yet.
Hopefully he will update the post here with the ROW support maps, mine were 2019 and so its good to have this new version!
Yes,
here is the map link (thanks Byront for that)
And here is prepared fixes:
ANZ 3G+ - 412.3 KB file on MEGA
ME 3G+ (untested yet) 412.4 KB file on MEGA
SA 3GHigh - 412.4 KB file on MEGA
SA 3G+ - 412.4 KB file on MEGA
Install the map, use the activator from very first post and then use the fix provided here.
Enjoy your new map.
Fixes for other parts of the map will be provided on demand
Reactions: 3
That didn't resolve it.
Is it because I don't have Green menu enabled?
Light Automotive design Motor vehicle Vehicle Gadget
Motor vehicle Automotive design Vehicle Audio equipment Personal luxury car
Motor vehicle Vehicle Gadget Automotive design Audio equipment
And this is after all the actions:
Font Gadget Audio equipment Electronic device Communication Device
@ccb : Someone reported Error 146 here: MMI 3G+/3GP navigation 6.31.1 and firmware updates -...
The reported solution then was to re-install the firmware.
Another post (from a different forum) also suggests this is related to the installed firmware: mm3g error 146 while updating SOLVED
Now, if you already updated to HN+R...K0942_4, you'll need access to the GEM to enable user-defined software update to be able to (re)select packages that were already updated. --g
There's an easier way to get User Defined mode (if you don’t need the green menu for anything else):
In file metainfo2.txt in the root folder, if you remove the line "MetafileChecksum=XXXXXX" and add the two lines
then you will be able to use the user mode w/o the green menu.
Now when you run the update, the MMI update process will enable User Defined as an option ...
Doesn’t the A6 have a later firmware update K1001?
Doesn’t the A6 have a later firmware update 1001?
Idk, but i was following the instruction as the OP posted.
Fyi, tried the other options but still got errors
Home appliance Entertainment Audio equipment Gadget Flat panel display
Personal computer Flat panel display Audio equipment Entertainment Display device
Personal computer Output device Computer Audio equipment Entertainment
Vehicle Entertainment Audio equipment Gadget Personal computer
Computer Personal computer Automotive design Audio equipment Netbook
Computer Personal computer Gadget Audio equipment Entertainment
So your firmware is up tp date, i have found that i had to do the following:
  1. In green menu, go into Nav and delete database
  2. In green menu, go into Nav and delete HDD Partition
  3. In green menu, go into Nav and select delete HDD Partition again, and make sure it tell s you that the partition is rebuilt and you need to install the maps database again
IF you don't get the message in the green menu, it fails to install the maps as it has no idea where to install them. After install i then had to use the firmware card to install the map styles and Gemmi files agian
I don’t think the 1001 update is freely available and BTW (for anyone reading) it’s only for HN+R systems ...
After much effort, I loaded the ROW map. But Turkey is not in it. Thanks for sharing friends.
During the update;
error code : 146 in map update
error code : 145 in map update
error code : 151 in fw update
error code : 150 in fw update
I encountered errors like I deleted the map database and deleted the hdd. But FW never loaded. I ran emergency update but it crashed to red screen. I was worried for a moment. But then I copied the original FW to a different SD card and it updated successfully. All errors have been cleared. Then I installed Row Map. But with all this effort, I could not reach the map of Turkey that I wanted. It's not in it.
To try and work on this while a resolution on the current problem is being investigated.
Could someone tell me which map update should I install on this FW?
Media version: HN+R_EU_AU_K0942_4
Nav. database version: 8R0060884BC ECE 6.16.3
Vehicle Motor vehicle Automotive design Gadget Font
These are the options I have chosen when I was performing this process.
Font Screenshot Multimedia Darkness Software
img redacted
The map level you tried is the correct one; it failed due to an issue you have with your MMI and not because it's the wrong version.
You've never told us where you started; what were the MMI and Map versions before you did any updates?
You've had various suggestions; I would:
1) Download the map files again onto a Windows PC and WINRAR to a PC folder..
2) Format the SD as FAT32 and use the file list in Post #1 to build the appropriate file structure on the SD by copying from PC. [This will fit a 32GB card]
3) Edit the metainfo2.txt to allow User Defined mode.
4) Run the update in User Defined Mode by selecting all the updates that revise levels.
5) If that fails; delete the map data [but not the partition] using Green screen and try again.
Yessss, found an image I took the day before I started to do anything with this.
Motor vehicle Vehicle Automotive design Car Gadget
In regards to your steps. I have tried every step but not the last one. I also don't know how to do it without any additional devices.
If you check my previous version and can see that there is a different reason why it isnt working for me, please let me know what to do.
If not, then I will try your fifth option :)
I really appreciate your help. <3
Did you read the manual from the very first page?
Did you deleted the hddnav partition and then tried to install map?
Sometime when you restart the mmi sooner than needed (during hddnav delete) you need to execute the delete one more time as the partition might be left in unusable state.
Its all in the manual, process was executed thousand times, if for some reason its not working on your mmi i would check the following:
1. SD card with the map
2. Use windows PC to write the files
3. Make sure SD is FAT32 and not exFAT or NTFS
4. Delete the HDDnav partition one more time (just in case)
Regards.
Regards.
I remember now.
This is the error I got when I extracted the file...
I have tried to download the file several times.
Below is mentioned a detailed breakdown:
Product Rectangle Font Screenshot Parallel
Downloaded 6.33.1 version from MEGA:
Terrestrial plant Font Science Astronomical object Screenshot
Download as ZIP
Rectangle Gadget Font Display device Automotive exterior
Open the downloaded ZIP file, open the first folder there:
Rectangle Font Parallel Screenshot Technology
Open the first archive file
Rectangle Font Parallel Number Screenshot
Highlight all, extract the files into a folder on my computer (I also tried straight into the sd card) and input the password for that download (8R0051884JD)
Font Sky Screenshot Darkness Event
