Correct. All worked as should. Activator was a bit different from manual but still easy and straightforward with common sense. Thnx.I don’t think 6.35.1 used a password.
Hi Congo, thanks for posting this stuff. Unfortunately, this map file appears to be missing several folders and won't install properly on my S4. The installer is looking for:NAR
6.20.1 2019/2020 MMI 3G ... here! If it asks for password then use this one -> 8R0060884GJ
Did you manage to get the 3 missing folders? I am in the same situation.Hi Congo, thanks for posting this stuff. Unfortunately, this map file appears to be missing several folders and won't install properly on my S4. The installer is looking for:
LIT_NAR
LIT2_NAR
LIT3_NAR
LIT4_NAR
But, the only folder present in the downloaded map pack is LIT4_NAR, and the update fails. Do you have a functional map pack for 3G High?
No, not yet. I actually haven't had any luck finding any functional map packs for 3G High yet. I found another thread on a different forum where someone had posted the 6.16 NAR maps for 3G High, but they're missing the two MMI3G and MMI3GP folders in the root that are supposed to have metainfo.txt in them. I'm getting close to biting the bullet and just buying a map pack for a hundred bucks, and if I do, I'll be sure to share it.Did you manage to get the 3 missing folders? I am in the same situation.
The MMI3GP came out in '12 or '13, so yes, the map pack for the MMI3GP should work for your '14. I installed it on my GF's '15 A4.maybe not the right place to ask, but will this work on audi a4 2014 quattro?
Which maps were you able to install? Once I get to the activation point, I'll be able to offer my input, but right now I'm just trying to find a map pack that isn't missing pieces.Hello Guys, i'm not abe to activate maps for 3G High. Attaching the logs from the script that @Dr.GER posted. Can someone help me. Thanks
Please can you help me how to download the link please 🙏Here's the requested screen:
In regards to the flash drive. Yes, I have gotten myself an adapter from AMI to USB and a 64gB flash drive formatted in exFAT.
FYI, the maps were extracted using the required password. There shouldn't be any problems there.
If you have a 2013 A8 with K0942 MMI and 2018 maps, you've obviously already updated them both from the version that came with your car.Hi Audi A8 2013 software HN+R_EU_AU_K0942_4 8R0060884FK ECE 6.27.2
What files do i need to upgrade the maps please
Perfect. Will give it a shot and let you know! Thanks@mubmoh It’s never a good idea to delete the maps and partition as it is a waste of effort and time (the map update deletes the original files as part of the logic). You spend extra time building the partition and copying files that you didn’t need to - nav updates don’t replace all the nav files on the nav partition!
However, as a result of deleting, you now need to run in User mode so that you can select all the non-bootloader files manually.
J
