This map is good for
MHI2_ER_AUG22_K3346 MU1438
NO! Do not use this file on your MMI it is not compatible.This map is good for
Can you direct me to the section for my mmi a4 2017?NO! Do not use this file on your MMI it is not compatible.
Audi changed the way their navigation database is licensed when the MIB MMI platform was introduced. See here for more info: MIB1 / MIB2 HDD 2020/2021 Navigation Map Update Package - V03959802 - Carsie.net --gCan you direct me to the section for my mmi a4 2017?
If you have a6 4f then you probably have 3g high, so vlasoff activator is not for you it is only for 3g+, not sure which one you used first...Hello. I managed to install "6.34.1 2022 MMI 3G High/Plus Europe" on my Audi A6 C6 4F, but the browser tells me "Navigation is disabled".
I have managed to install the activator, and the screen shows me "already installed", but the error continues.
I have not managed to install the other map activation "6.22.4 Vlasoff maps activation", I insert the SD card but it does nothing.
please give me a hand.
Jose
Hi Mario, thanks for your reply.If you have a6 4f then you probably have 3g high, so vlasoff activator is not for you it is only for 3g+, not sure which one you used first...
