3761 - 3779 of 3779 Posts
Hello all,
I am new here and I am grateful to be here.
I have just updated my 2014 Q5, MMI 3G+/Nav+.
Everything went smooth, MMI to K_0942 and the MAPS to 6.28.2.
Activator 6.22.4 Vlasoff.
First try to activate, failed : nothing happened and navigation still blocked.
Second try: after little while, MMI rebooted, Navigation Activated !
I drove a bit arround and navigation works perfect.
Although :
I had error 03276, but I managed to clear it, thanks to the manual.
Now I still have error 03623 Invalid Security/release code.
I am not able to remove it, following the instructions in the manual.
Is it necessary to clear the error ? Will navigation keep on working ?
Activation succeeded, but had some errors in the install.log :
WLAN not found, ignition on ? (maybe this was first try)
WLAN number EEPROM not found, but we now what we are doing. (probably wrong X-code; calculated manually)
Installation succesfully
Can you please advise ?
Thank you
Hi Barrie.
Can you hook me up with the firmware and all the requisites you used?
I purchased an update online but for some reason once started asking questions, related to the problems that came up upon update, the seller stopped responding. 🙄 I want to try all reasonable options before paying $800 to a dealer.
I have a ‘14 model Q7 w 3G+, which has the same MMI as your Q5.
TIA
HELP!!!!
I just did firmware updates for my MMI Audi A6 2014 importer from Japan to Europe, first I did a forced update and after with HN+R_EU_AU_K0942 - Stock firmware .... all good but... I don't see anything written on display is like all the options are there, I can go anywhere to scroll down and up but I don't know what is because is nothing written on display...
Can somebody help me, please?
Thank you.
HELP!!!!
Thank you.
MMI 3G+/3GP navigation 6.31.1 and firmware updates - currently 2020/2021
Map & activator (activator works for 2018/2019 maps):
8R0 060 884 GA - 6.28.2 2019 MMI 3G High/Plus Europe 2019 [Link on Mega (use 7z/7zip to open the files)]
2020/2021
8R0 060 884 HF - 6.31.1 2020/2021 MMI 3G High/Plus Europe 2020/2021 [Link on Mega (use 7z/7zip to open the files)] Password: 8R0060884HF
8R0 060 884 DF – Activator [Link on cloud.mail.ru || Link on Mega]
Firmware:
Audi A1 [Link on cloud.mail.ru || Link on Mega]
8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Audi A4-A5-Q5-Q7
HN+_EU_AU3G_K_0900 - Stock firmware
HN+_EU_AU3G_K_0942 - Stock firmware
HN+_EU_AU3G_K_0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
HN+_EU_AU3G_K_0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Audi Q3-A6-A7-A8
HN+R_EU_AU_K0900 - Stock firmware
HN+R_EU_AU_K0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
HN+R_EU_AU_K0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Manual:
3G_3GP.pdf [Link on Mega || Spanish translation thanks to homarc || 2017 MAP Update thanks to homarc]
Cheers :wink2:
In order new 2019 map to fit in 32GB SD do not copy the following folders
pkgdb/LIT
pkgdb/LIT2
pkgdb/LIT3
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
Warning - FW update K0900 is removing the "Emergency Update" option from the "Green Menu". There is a way that this can be fixed.
• Emergency menu activation on K0900 firmware. [ Only for A5OC ]
• To enable the Green Menu you could use VCDS, VAS or the following script [ Green menu activation ]
• 03623 [ 03623 Remove ]
1. Unzip it on the SD card.
2. Put the sd card in the MMI.
3. When prompted press the center knob.
4. After the script is done you will see confirmation screen.
5. Remove the SD card and reboot MMI
Do not use MAC to unpack and/or copy the files to the SD card.
Q&A section
A. Not for now.
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
Q. Have found the activation script and it includes "2380_00040009.fsc". This should be changed according to manual Page 31 to the MAC address specifically to my MMI or should I continue to use the "2380_00040009.fsc" as stated in the manual page 18.
A. Leave the filename as it is now.
Q. The 2380_00040009.fsc file contains a VIN number. Should that be changed to my VIN number?
A. No, do not attempt the edit the fsc file.
Q. Will my VIN be visible and correct in the MMI
A. Yes.
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Q. What does the new firmware bring in terms of added functionality?
A. Not much, apart from K0770/K0767 fixing the issues with the SIM data connection and Bluetooth usage at the same time.
skipMetaCRC = "true"
Recovery of "bricked" MMI 3G units, RNS850 unit, MIB1/2 units, PCM4/5 units.
Google Earth/Sreet View on RNS850 and all MIB1/2 units, PCM4/5 units
Hello I need help...
I did update to my MMI and all are ok the only problem is that I have nothing written on the display... You can use it just is nothing on display...
Can you please help me out?
Hi Guys- sorry quick question, is the activator for the maps only ? (not the firmware?) and is the activator specific to a map version, a firmware version or both?
Want to update maps but not the firmware if possible (currently HN+_EU_AU3G_P0530) to avoid risk and hassle.
Mariano
You never need to activate firmware, it's for the maps only.
Reactions: Dizzly
Thanks so much for uploading this. I'm trying to run the firmware update on my 2010 Q5. It has never been updated. I have train version P0022, and MU software 0048. It won't take the update I downloaded from this thread,or the older ones. I get this error: "a variant conflict occurred.
main unit variant 9303
Release info variant 9498" or for the other one I tried, 9307 9308.
What am I doing wrong, is this not the right update for my car?
Any help will be greatly appreciated, as I'm sure this firmware update will fix a problem with my aftermarket DAB+ radio. Thanks in advance.
Edit: Guess I got it mixed up, I have 3g basic, not high/plus, right?
Edit2: Updated now, DAB radio works.
I just bought a 2013 s6 and would like to know if anyone in the Indianapolis Area is available to do the software update and nav update for a fee. Thank you!
Hi guys, …I can’t login in to edit eeprom at 5f using vcp cable. what’s the security access? MMI serial is …K5FAN15ZAIIE7. have tried 21055, NEA7I, NAII7 in vain….please help, need to edit eeprom language
I'd might be wrong but can't you change that in the hidden green menu, that can be enabled by VCDS?
Thanks for the reply….am attempting to change the mmi eeprom language so as I can unbrick it…so I have connected the my car with a laptop using a vag can pro cable
Hi all ,I have a 2014 A4 with the b&o sound system I'm pretty good with computers (service desk engineer) but not really done much with cars any help would be appreciated on which files exactly I would need this is my MMI info
181040
Can you advise if the order for updating is run modified firmware update first , then maps then activator and if there is anything to be aware of during the process also and estimate on how long it takes to process :) sorry for the questions
Administrator
You have the process correct. Please read the instructions in the first post. This should answer your questions.
2011 Audi A8
It's all in the guide in the 1st post Matthew
