You have a 3G HIGH unit!Thank you, most appreciated.![]()
is this work for high or not? Other topic says nothing about high... A4 Avant 2011 3G High
you are in the wrong topic.is this work for high or not? Other topic says nothing about high... A4 Avant 2011 3G High
Hi, so on page 1 there is description of folders not to include to the SD card. If SD card is of good quality files will fit. I had to buy a new SD card to make it happen. I had a non-brand SD card an it did not work. Hope it helps youHi everyone,
i want to know how i can send 35gb of mmi update file to 32gb sd card? I downloaded the compress file which is 24gb and once extracted with 7-zip and it is 35gb.
Hi yes it's work thank youHi, so on page 1 there is description of folders not to include to the SD card. If SD card is of good quality files will fit. I had to buy a new SD card to make it happen. I had a non-brand SD card an it did not work. Hope it helps you![]()
Thanks for your quick reply albert. Yes i took pictures of the original value and made sure they are all back to original.a quick google took me to this :
03157 - check the encoding and the settings of the CAR menu in the green menu: either you turned on something in the green menu, which is not in the car, or vice versa. In short, it is necessary to bring the coding and MMI settings in line with the real filling of the car according to the options
are you sure your green menu settings are back where they started? Did you take photos of them before?
Albert
Go on then...elaborateFixed the 03157 fault code.
I get this when i try to start software update.-> The medium is currently unavailable.Hi,
Yes, as per page 1:
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
This also include K0942.
Maps per manual, is to be deleted before upgrade, more exact MMI partition and HDD.
New map will be installed as new and not a upgrade.
You are good to go, BUT, you must follow the manual, this is important to make sure everything works as expected.
I had reservations like you, but I updated my Q7 her the other day as you can see on the past to pages on this tread.
Worked like a charm.
Remember do download green menu activator and install it first. And Map activator to enable maps after map install.
I had two option on carbussassiggnment that were turned on but not mirrored on cardevcelist and carmenuoperation. Just had to figure out if I had these options in my car or not and whether to either turn them on or off on all of the above options. Once I got the correct setting the fault code disappeared, lucky for me as I didt completely mess up the settings in the green menu. No more Acc, abs tpms etc, coming up.Go on then...elaborate
Hi, following the guide did you remove the nav partition and HDD using green menu before trying to install the new 6.32.1 maps?Hello
I have installed FW 942_4, then maps 6.31.1. Then I have downloaded the 6.32.1 maps and wanted to write them. So that I don't get any DTCs I have activated the Green Menu, followed the entire erase process for the maps/format hdd. I have tried to install 6.32.1 and I can only install STANDARD and no custom install, and by standard it has only installed : MapStyles and TMCConfig, AUDI_MMI3G_ECE and NaviPersistence were (standard) selected to "N" and can't change that. Did the update but no joy. Then I erased again database and deleted nav partition, reinstalled 6.31.1, work like a charm, BUT when I inserted card with 6.32.1 now I get NO updates. I can only install standard, no custom, and as standard, all options are preselected with "N" ! What am I doing wrong ?! How can I install 6.32.1 ? Then, on another subject I get these 2 DTCs : 03276 - Checking Software Version Management and 03623 - Release Code Faulty.
Also tried to follow instructions for clearing 03276, by going to system 5F Information Electronics, channel 15 etc but can't write the values I obtained recalculating the count value and storing/saving the new value, but I can't write/save to this Channel ...
Any ideas ?
Thank you !!
