3321 - 3340 of 3371 Posts
(1) You have P0925 which is higher than K0900, so do not apply!
(2) Read the istructions as everyone says. No shortcuts!
(3) See #2 above!
Reactions: JeyPi
does anyone know where you can get the maps data for the 3g high system from? the link in the thread is no longer active.
Simon
3.0TDI CDUC SB Stronic
Simon
It is still valid as i am downloading firmware and maps right now.
btw. i am downloading 8R0 060 884 GA - 6.28.2 2019 MMI 3G High/Plus Europe 2019 and • HN+_EU_AU3G_K_0942
My current version is P0662 and navi ECE 6.16.3, does it fit for me?
My concern is that it was pointed out the files are different for the 3g high and 3g+ and these files are for the 3g+ - I don't want to screw mine up by using the wrong files.
Simon
hi just wondering if you could give me instructions too on how to update my firmware and maps never done this before here’s a pic of version thanks so much
you will have to go over this topic and stat at the first post.
you will find full instructions there.
So i downloaded the HN+_EU_AU3G_K_0942 and after it has finished installed i got a red screen with following message: MMI3G EmApp 37.26.2098 MU9498 Mount error Update failed! Trigger shutdown after countdown. I guess i did something wrong. This is for my Q5.
Hi, in order to make the Maps Update, do I need to copy all of the files on SD card from 1-21? or just one file is enough? I've downloaded from the Link and File no.1 its a File that it can opend in Daemon Tools and the rest 2-21 are just files that i can't open. Do i need all of them copyed on the SD Card? Thnx
Hello gentlemen,
I have a problem with positioning after updating in A8. FW P1001, 6.30 EU maps, KELDO activator. The device does not show the correct position. I have already traveled about 100 km on it and it still hangs somewhere in Ukraine. Is there any way to fix this error? I tried to reinstall FW again, and downgraded to version K0900, but not in EM. Please help.
Hello gentlemen,
the p1001 Fw only good for A6, not good for A5
Bonjour à tous !
J'ai une Audi A6 3.0 TDI Avus Multitronic de 09/2011.
Mon MMI est en version: HN + R_EU_AU_P0475 (Une version spéciale pour laquelle je n'ai pas trouvé d'informations sur l'Audi A6 C7)
8R0060884N ECE 5.12.5
Je ne possède ni le Bose Sound ni le Bang and Olufsen
J'ai le MMI Connect avec carte SIM au milieu des 2 cartes SD
J'ai trouvé beaucoup d'informations sur le forum pour la mise à jour du firmware mais je ne peux pas être sûr de pouvoir le faire à partir de la version P0475.
- Pouvez-vous me dire quelle version je dois utiliser pour la mise à jour du firmware et de la carte sur cette version de MMI?
- Puis-je mettre directement le K0900 puis passer au dernier en K942 (je pense que c'est le dernier)?
- Pouvez-vous confirmer quel tutoriel précisément je dois suivre pour ne pas faire d'erreurs?
Je ne veux vraiment pas brique mon MMI lol
Merci beaucoup pour votre retour! Très bon week-end! :)
