3221 - 3226 of 3226 Posts
Hi everyone, stupid question:
During firmware update at the initial stage in standard mode 95% of the modules are marked N and one as S the rest is Y or N/A...
If I check all options to Y apart from the Bose components, is there any chance that I do something wrong? My assumption is that if a component is missing from my car, the upgrade will skip it ? Or is there a list of what folder in the firmware update means which component ? Would be nice to know what to check, like GEMMI for Google maps, etc...
Just registered to say thank you to @congo. Audi SQ5 2014 with B&O
Was firmware P0782 with MAPS 6.19.3
Now firmware K942_3 with MAPS 6.28.2
Took my time reading the original post.
Installed the Mega Sync/Windows 10 App and downloaded the maps - takes ages took like a couple of days to do map pack (23GB compressed) if you don't want to pay for megasync! do the firmware/activator/green menu 1st!
Used a 16GB SD Card for the green menu activator (have to do this after every reboot/engine off-start up).
Used 32GB Card for the firmware - did the user defined tick green menu, then engineer menu updated firmware on the defaults
Used 64GB USB Stick (Formatted FAT32 (32)) with full map expansion unzipped on to it! this is a very slow process! took about 20mins to copy even to a usb stick which is faster than a memory card. I have the MMI to USB adaptor.
1st Green Menu/Engineer Menu tested i knew what i was doing
2nd Firmware updated fine
3rd MAPS updated - Took nearly an hour and half to do! but did it, looked like it was working and then "no data" came up.
4th Cleared off the 32GB card from the firmware and copied the map activator (make sure you label it ACTIVATION). Put in SD1 left for 2mins and it rebooted itself. Didn't tell me what it was doing.
MAPS then worked.
Notes: I have the B&O and throughout it all i never had in the updates anything called BO/BOSE or relating to B&O that i could see to deselect. I changed none of the Y/N left on defaults assuming it would pick the updates if they were needed - Assumed correct as it all works. Also once finished take your car for a good thrashing, sat idling for a few hours my DPF filter light came on - lol put in dynamic/sport and used manual to leave in gears longer soon cleared it off.
Not the easiest update for a noob to complete; but take your time read the instructions and it is achievable, oh another note i used youtube a few times watching people do it, as getting in to the engineer and green menu is different from car to car. mine being a Menu/Back/Car mix up. I have seen 6.30.1 is released wont be rushing to find it as boy it takes ages to the above. However as you are reading this you are doing it to save the £££ a dealer would charge you.
Next MOD is
Stop the car from beeping when you open the door with the key in the ignition (yes can press reset to stop it once)
Google Maps << anyone know how to get this activated in the maps
Apple Car Play << seems to be do able but pricey
Anyone got any advice on them please DM me. Much Appreciated and once again thank you Congo.
HN+_US_UA3G_K0942_3 -->> HN+_EU_AU3G_K0942_3 + modified EEPROM - Languages EU version (upgrademyaudi.net) = NO DISPLAY MMI TEXT MENU :(
What am I doing wrong?
Next MOD is
Google maps will be already installed on there, you may have to reinstall the last firmware again and google maps will appear in the maps selection where you pick 2d, 3d and so on.
Also for google maps you require a sim card in the slot between the sd card slots.
