1 - 20 of 3336 Posts
MMI 3G+/3GP navigation 6.28.2 and firmware updates - currently 2019
Map & activator (activator works for 2018/2019 maps):
8R0 060 884 GA - 6.28.2 2019 MMI 3G High/Plus Europe 2019 [Link on Mega (use 7z/7zip to open the files)]
8R0 060 884 DF – Activator [Link on cloud.mail.ru || Link on Mega]
Firmware:
Audi A1 [Link on cloud.mail.ru || Link on Mega]
8R0 906 961 EC – HN+_EU_AU210_K0900 (A1) SVM: 3GPEU900A1
Audi A4-A5-Q5-Q7
HN+_EU_AU3G_K_0900 - Stock firmware
HN+_EU_AU3G_K_0942 - Stock firmware
HN+_EU_AU3G_K_0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
HN+_EU_AU3G_K_0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Audi Q3-A6-A7-A8
HN+R_EU_AU_K0900 - Stock firmware
HN+R_EU_AU_K0942 - Stock firmware
HN+R_EU_AU_K0900 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
HN+R_EU_AU_K0942 Modified firmware - Green Menu enabled / User Defined Mode / No Sound systems
Manual:
3G_3GP.pdf [Link on Mega || Spanish translation thanks to homarc || 2017 MAP Update thanks to homarc]
Cheers :wink2:
In order new 2019 map to fit in 32GB SD do not copy the following folders
pkgdb/LIT
pkgdb/LIT2
pkgdb/LIT3
You might need GEM (Green engineering menu) activated and use User Defined Mode and manually select all that is under AUDI_MMI3G_ECE if it's not selected.
Warning - FW update K0900 is removing the "Emergency Update" option from the "Green Menu". There is some info that this can be fixed but i dont have 3GP unit so i cannot personally try the script that i have created for that :(
So if there is someone willing to try it just let me know.
• Emergency menu activation on K0900 firmware. [ Only for A5OC ]
• To enable the Green Menu you could use VCDS, VAS or the following script [ Green menu activation ]
• 03623 [ 03623 Remove ]
1. Unzip it on the SD card.
2. Put the sd card in the MMI.
3. When prompted press the center knob.
4. After the script is done you will see confirmation screen.
5. Remove the SD card and reboot MMI
Do not use MAC to unpack and/or copy the files to the SD card.
The problem:
I've tried to update my firmware (MMI 3G+) to K0767 and got the following error:
GEMMI_nav:0 error code 141
I could only access "Retry" choice (but update kept blocking at 5% with the same error) or "Back" button that was useless
Unable to do anything else, even the Reset procedure didn't work!
Root cause:
This is a file corruption error, the MMI didn't like what it found on the SD card.
Because I'm a stupid software engineer who thinks he knows best, I didn't trust the forums and copied the files from my mac onto the SD card (using command line to clean-up the .Trashes/ and alike folders)
So this is the lesson: DO NOT COPY FROM A MAC
Sub-lesson: better learn from other's mistakes than redo the experience...
Solution:
As stated previously, even a MMI reset procedure didn't allow me to get out of the error.
So I went to my neighbour's Windows PC, reformatted the SD card and extracted the RAR archive onto it.
Back to the car, update went fine and completed successfully after 30 minutes
Hope this experience will help some fellow here...
LESSONS LEARNED - NEVER USE MAC OS (or Unix, Linux based OS) for unpack and copy map or firmware data into SD card. Also always format SD card in Windows OS. USE ONLY WINDOWS FOR UNPACK/COPY!!!
I had to upgrade Firmware as well. I could not load map data even they were copied in windows. It means that also Firmware was corrupted.
I found cca 10 000 hidden files on Firmware SD card. Dangerous is that Firmware seemed to be OK all the time but it was not and I could destroy whole MMI
(Imagine that FPGA or EEPROM is burned with some hidden apple .bin file....).
Q&A section
A. Not for now.
Q. I have mmi 3gp , version p0XXX can i go straight to k0900?
A. Yes.
Q. Have found the activation script and it includes "2380_00040009.fsc". This should be changed according to manual Page 31 to the MAC address specifically to my MMI or should I continue to use the "2380_00040009.fsc" as stated in the manual page 18.
A. Leave the filename as it is now.
Q. The 2380_00040009.fsc file contains a VIN number. Should that be changed to my VIN number?
A. No, do not attempt the edit the fsc file.
Q. Will my VIN be visible and correct in the MMI
A. Yes.
Q. Only thing is that my Google Maps option is greyed out... any hints?
A. Reinstall the GEMMI_nav component from the K0900.
Q. What does the new firmware bring in terms of added functionality?
A. Not much, apart from K0770/K0767 fixing the issues with the SIM data connection and Bluetooth usage at the same time.
skipMetaCRC = "true"
Recovery of "bricked" MMI 3G units - 3G Basic (DVD-Rom;7T2), MMI 3G/3G+ (HD;7T6), RNS850
MMI 3GP K0900 MAP 2016, MMI 3G HIGH K0257 MAP 2016, MMI 3G BASIC K0260 MAP 2016, MMI 2G HIGH 5570 MAP 2016
Coding of STG 46 Halogen to LED tail lights A4/8K A5/8T A6/C7 A7/4G || Turning off start-stop system
Google Earth/Sreet View on RNS850
Hey guys, I just got myself an Audi A5 Sportback from 2013. I checked and I believe this is still running the MMI firmware and maps from then as well.
The MMI version information:
Media version: HN+_EU_AU3G_P0612
Nav. database version:
8R0060884AR ECE 6.15.5
I believe this is the right topic for my version, however can anyone confirm this and the best way to get to this latest version? As this is the first time for me doing this and I only just got the car, I don't have the VCDS cable or software yet. From what I read it will take a long time to actually install the maps and firmwares, which means either the car will be running for a long time, or I'd need to get a charger for the battery to ensure it doesn't run out.
Which leads me to the next question.. Buying a cable with the software (a proper one and not a knock-off with grey area software) and either buying a charger or running the car the whole day, why shouldnt I just get this done at a dealer/garage? As I've never done a thing like this, I would like to get to know more about it as I am interested, but currently it looks like there are a lot of additional costs involved no matter which way I get the latest maps.
Thanks in advance!
Well, you don't have VCDS cable and you have never done such kind of things I will suggest to you two options. Either find someone local to you that have experience in this area or go to the dealer. The manual in this topic is complete and tested many times but to be honest there is always room for error. Is it the right way to do it using the info found here .... well define "right". It is illegal if you ask Audi.
Nah, that's ok, i didn't mean the right thing in that way. I already knew that ;)
I meant right more in a money and time spending way. I was thinking about finding someone local as well. So I'll probably pop in a post in the UK forum part to see if there is anyone nearby enough.
Thanks congo!
Discussion Starter #5
Ah i got it wrong then ;) about the right way :)
The rest ... if you can find someone local than good if you cannot i can guide remotely...
Anyone in the Netherlands that has experience with this? I want to upgrade my 2014 Audi A5 Sportback MMI but have never done it before and don't want to brick my unit.
yes, I have and it works :)
are you sure you have a MMI 3G and not a MMI 3G+ ??
I ask this, as you car is 2014.
show us yr version info.
is it HNav or HN+ ??
Not sure how to tell if it is a MMI 3G or MMI 3G+.
But I think a MMI 3G+ since I have Audi Connect with Google Maps too.
According to the MMI info it is a HN+, see attached image.
this is definitively a MMI 3G+
which means you can't do the activation by yourself.
This means I have to use Keldo's activator for example?
So to upgrade my MMI I have to first upgrade the firmware, then upgrade the map software and then activate the unit?, but which version do I need? And is it also possible to only upgrade the firmware and do the maps later?
• 8R0 906 961 BK – HN+_EU_AU3G_K_0517_4 (A4/A5/Q5/Q7) SVM:3GPEU517
• 8R0 906 961 CA – HN+_EU_AU3G_K_0612_2 (A4/A5/Q5/Q7) SVM:3GPEU612AU3G(w/o SIM)
• 8R0 906 961 CE – HN+_EU_AU3G_K_0614_2 (A4/A5/Q5/Q7) SVM:3GPEU614AU3G(w SIM)
• 8R0 906 961 DH – HN+_EU_AU3G_K_0767 (A4/A5/Q5/Q7) SVM: 3GPEU767AU3G
• 8R0 906 961 EB – HN+_EU_AU3G_K_0900 (A4/A5/Q5/Q7) SVM: 3GPEU900AU3G
• 8R0 906 961 AK – 3G_DAB_K0097 (A4/A5/Q5/Q7) SVM: 3GPRU0097
It won't be easy because you have Bose sound system ask Congo he can help
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Hey Guys, just want to confirm a few things here.... All the files/maps above are for Europe correct?
Currently no updates for North America? ...aside from that, I would think I have the latest versions on my 2016 S5?:
