Hi guys!
I'm trying to crack a little mystery with traffic Sign Detection and google Earth displaying on dash. The car i'm trying to get these working with is A5 Sportback 2018, with 7S9 dash, MiB2 High scale (delphi) with SD Navigation, windshield camera unit present. I activated VZE with Kufatec dongle without any errors. The system is recognizing speed and few other signs fine, but i'm not getting "supplementary traffic sign display" which should be shown in left corner on the dash. Dashboard SW is 629. MMI 0213. Traffic sign msg bus is set to Terminal 15 by default. Any suggestion what to do / check ?
The second issue i'm having is with Google earth, which is successfully activated and working on MMi display, but when switched from RLE options to "most streaming" (in 5F adaptations to display map on dash) GE option in MMi gets greyed out, defaults back to standard view and only GE loading bar is shown both in MMi and dash displays. Can someone help me out here ?
Here's Full code Scan with VCD:
VCP+K v8.7.9 16.04.2021 "#WeAreStillHere" Autoscan protocol 2021-05-27 22:50:51.319
VCP+K v8.7.9 16.04.2021 "#WeAreStillHere" Autoscan protocol 2021-05-27 22:58:37.546
Adressword : 01 (Engine Control Module 1} - J623 R4 2.0l TDI
VAG no. : SW: 04L906026AG HW: 04L907309L
SW version : 9970
# Coding : 0A25403A233605083428
ASAM: UDS, EV_ECM20TDI01104L906026AG 005010
DATASET:
Adressword : 02 (Transmission Control Module} - J217 0CL 20TDIRdW
VAG no. : SW: 8W2927155BD HW: 0CJ927156
SW version : 0001
# Coding : 000001
ASAM: UDS, EV_TCMDL382021 002027
DATASET:
SLAVE[1] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[2] Part number: 0CK927152AA
N/A SW: N/A HW: N/A
Coding : N/A
Adressword : 03 (Brakes 1} - J104 ESP9 Plus
VAG no. : SW: 8W0907379K HW: 8W0907379J
SW version : 0766
# Coding : 0CAA489A28A60A9D51A2489700845292E4A5DA301214508A12004A4927A55B
ASAM: UDS, EV_ESP9BOSCHCMP 002013
DATASET: 8W2909504D
Adressword : 08 (Air Conditioning} - E87 Klima Zone 3
VAG no. : SW: 8W0820043T HW: 8W0820043T
SW version : 0210
# Coding : 141844195544400D02000100880000000000000000000000000000000000
ASAM: UDS, EV_AirCondiBHTCAU491 001013
DATASET: -----------
SLAVE[1] Part number: 4H0907658A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[2] Part number: 8W0919158
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[3] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[4] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[5] Part number: 4M1820021A
N/A SW: N/A HW: N/A
Coding : N/A
Adressword : 09 (Central Electrics} - J519 BCM1 MLBevo
VAG no. : SW: 8W0907063CG HW: 8W0907063BG
SW version : 0267
# Coding : 07501943E17900CD0505871418BD80F9110B310C000000000000000020001A810A450123025705
ASAM: UDS, EV_BCM1BOSCHAU736 018006
DATASET: 8W2909514E
SLAVE[1] Part number: 8W6955119
494 LL 210717 SW: 0471 HW: 8W6955119
Coding : 5FC7F7
SLAVE[2] Part number: 81A955555A
G397_RLFSS SW: 0002 HW: 81A955555
Coding : 02005D
SLAVE[3] Part number: 4M0941531AA
E1 - LDS SW: 0008 HW: 4M0941531AA
Coding : N/A
SLAVE[4] Part number: 8W0857511
Y7_Innenspieg SW: 0002 HW: 8W0857511
Coding : 030000
SLAVE[5] Part number: 8W0947135CN
J528-Dachele SW: 0130 HW: 8W0947135
Coding : N/A
SLAVE[6] Part number: 8W0907182
J873 MKS_FSv SW: 0034 HW: 8W0907182
Coding : 1E0500
SLAVE[7] Part number: 8W0907182
J872 MKS_BFSv SW: 0034 HW: 8W0907182
Coding : 120500
SLAVE[8] Part number: 8W0925301BC
SL-B9/Q5NF SW: 0010 HW: 8W0925301BC
Coding : 000000
Adressword : 15 (Airbag} - J234 Airbag10.44
VAG no. : SW: 8W0959655F HW: 8W0959655F
SW version : 0106
# Coding : AACCF0C00C800000585400F3D04C00000000
ASAM: UDS, EV_AirbaAU10BPAAU736 006015
DATASET: 8W2909602AC
SLAVE[1] Part number: 4M0980945
BeltPretRevFL SW: 2033 HW: 4M0980945
Coding : 88001B
SLAVE[2] Part number: 4M0980946
BeltPretRevFR SW: 2033 HW: 4M0980946
Coding : 88001B
SLAVE[3] Part number: -----------
SideSensor_Df SW: 0887 HW: 44206180817
Coding : 2D2D2D
SLAVE[4] Part number: -----------
SideSensor_Pf SW: 0887 HW: 44206180817
Coding : 2D2D2D
SLAVE[5] Part number: -----------
SideSensor_Dr SW: 0148 HW: 4420B300817
Coding : 2D2D2D
SLAVE[6] Part number: -----------
SideSensor_Pr SW: 0148 HW: 4420B300817
Coding : 2D2D2D
SLAVE[7] Part number: -----------
FrontSensor_D SW: 014A HW: 4420C280617
Coding : 2D2D2D
SLAVE[8] Part number: -----------
FrontSensor_P SW: 014A HW: 4420C280617
Coding : 2D2D2D
SLAVE[9] Part number: -----------
PedP_Sensor_C SW: 014A HW: 4420C290617
Coding : 2D2D2D
SLAVE[10] Part number: -----------
PedPSensor_D2 SW: 0887 HW: 44243110817
Coding : 2D2D2D
SLAVE[11] Part number: -----------
PedPSensor_P2 SW: 0887 HW: 44243110817
Coding : 2D2D2D
Adressword : 16 (Steering Column Electronics} - J527 Lenks.Modul
VAG no. : SW: 4M0907129HN HW: 4M0907129HN
SW version : 0009
# Coding :
ASAM: UDS, EV_SMLSKLOAU736 006008
DATASET:
Adressword : 17 (Dash Board} - J285 TDIeRDW
VAG no. : SW: 8W6920771A HW: 8W6920771A
SW version : 0629
# Coding : 05AC41C6688C00080C2369601000600000000000
ASAM: UDS, EV_DashBoardAU736 001027
Adressword : 18 (Auxiliary Parking Heater} - J364 HSG
VAG no. : SW: 4M0265105E HW: 4M0265105E
SW version : 0090
# Coding : 0D0F01
ASAM: UDS, EV_AuxilParkHeateEBEAU736 001016
DATASET: 8W2909858C
Adressword : 19 (Gateway} - J533 Gateway
VAG no. : SW: 8W5907468E HW: 8W5907468E
SW version : 0118
# Coding : 030100010000064041070000005900124C180007100000000175078F10000000
ASAM: UDS, EV_CGateCONTIAU491 003092
DATASET: 8W2909515C
SLAVE[1] Part number: 8W0951523H
J453 MFL SW: 0002 HW: 8W0951523H
Coding : N/A
SLAVE[2] Part number: 8S0915181C
J367-BDMHella SW: 9070 HW: 8S0915181C
Coding : N/A
Adressword : 29 (Light Control Left} - J1018 LCM_MLBevo
VAG no. : SW: 4M0907397AB HW: 4M0907397B
SW version : 0024
# Coding :
ASAM: UDS, EV_LCMLeftHELLAAU736 001012
DATASET: 8W2909519B
Adressword : 39 (Light Control Right} - J1023 LCM_MLBevo
SW version : 0024
# Coding :
ASAM: UDS, EV_LCMRightHELLAAU736 001012
DATASET: 8W2909520B
Adressword : 3C (Lane Change Assistant} - J769 MRR1Rear
VAG no. : SW: 4M0907566D HW: 4M0907566
SW version : 0410
# Coding : 1E8002
ASAM: UDS, EV_RearRadarS1BoschAU736 001022
DATASET: 8W2909535B
Adressword : 42 (Door Electronics Driver Side} - J386 TSG FS
VAG no. : SW: 4M0959793H HW: 4M0959793F
SW version : 0131
# Coding : 001FCB624000008000001430
ASAM: UDS, EV_DCU2DriveSideMAXHCONT 001005
DATASET: 8W2909872D
Adressword : 44 (Steering Assistance} - J500 EPS_MLBEVO_ZF
VAG no. : SW: 8W0909144H HW: 8W0909144B
SW version : 0410
# Coding : 09008380008000
ASAM: UDS, EV_EPSZFAU49X 003023
DATASET: 8W2909852P
Adressword : 46 (Central Module Comfort System} - J393 BCM2 MLBevo
VAG no. : SW: 8W0907064DC HW: 8W0907064DC
SW version : 0366
# Coding : 01340000002000E06303A0006E00480233024000804B06502F0400000504803F001F0000000000
ASAM: UDS, EV_BCM2HellaAU736 013013
DATASET: 8W2909501D
SLAVE[1] Part number: 3AA962243H
GEB.F.Heckoef SW: 0904 HW: 3AA962243H
Coding : N/A
SLAVE[2] Part number: N/A
N/A SW: N/A HW: N/A
Coding : 000000
Adressword : 52 (Door Electronics Passenger Side} - J387 TSG BFS
VAG no. : SW: 4M0959792H HW: 4M0959792F
SW version : 0131
# Coding : 001FCB224000008000001430
ASAM: UDS, EV_DCU2PasseSideMAXHCONT 001005
DATASET: 8W2909873D
Adressword : 5F (Information Control Unit 1} - J794 MU-HS-N-EU
VAG no. : SW: 8W0035183G HW: 8W0035183A
SW version : 0213
# Coding : 01940301FF0A000053110001000A00002F000EE401E000008E
ASAM: UDS, EV_MUHigScl6C3DELP 001011
DATASET: 8W2909545N
SLAVE[1] Part number: 8W0919614N
ControlUnit_B SW: 0134 HW: 8W0919614N
Coding : N/A
SLAVE[2] Part number: 8W1919604
DU Std AU49x SW: 0170 HW: 8W1919604
Coding : N/A
------------- SW: ---- HW: -----------
Coding : N/A
Coding : N/A
Coding : N/A
SLAVE[6] Part number: V03959803PK
ECE 2020/2021 SW: 0052 HW: -----------
Coding : N/A
Adressword : 69 (Trailer Function} - J345 Anhaenger
VAG no. : SW: 4M0907383F HW: 4M0907383B
SW version : 0253
# Coding : 0110000202000000
ASAM: UDS, EV_TrailFunctGener2Hella 001008
DATASET: 8W2909527A
Adressword : 6C (Camera System Rear View} - J772 RVC Compact
VAG no. : SW: 4M0980556A HW: 4M0980556A
SW version : 0250
# Coding : 0294030103002005400040
ASAM: UDS, EV_CamSysRVRVCPANAMLBEv 005010
DATASET: 8W2909460C
Adressword : 6D (Deck Lid Control Unit} - J605 HDSG-Modul
VAG no. : SW: 8W8959107B HW: 8W8959107
SW version : 0163
# Coding : 06B0
ASAM: UDS, EV_DeckLidCONTIAU736 001015
DATASET: 8W2909541B
Adressword : 7E (Dash Board Display Unit} -
VAG no. : SW: HW:
SW version :
# Coding :
ASAM: Communication error.
DATASET:
Adressword : 81 (Gear Shift Control Module} - J587 GSM-LL
VAG no. : SW: 8W1713041G HW: 8W1713041J
SW version : 0077
# Coding :
ASAM: UDS, EV_GSMWaehlZFAU736 001017
Adressword : A5 (Front Sensors Driver Assistance System} - R242 BVS
VAG no. : SW: 8W6907217A HW: 8W6907217A
SW version : 0050
# Coding : 0404090300000403022023A3A40000FC90F0C020C020
ASAM: UDS, EV_BVSMLBevKOSTAAU736 002026
DATASET: 8W2909466C
Adressword : AC (Reductant Control Module} - J880 SCR-Stg-G3
VAG no. : SW: 4M0907355D HW: 4M0907355B
SW version : 0006
# Coding :
ASAM: UDS, EV_RDCMINERGAU736 005012
DATASET: 8W2909571D
Adressword : CA (Control Module For Sunroof} - J245 SAD_STG_1
VAG no. : SW: 4M0907594J HW: 4M0907594
SW version : 0005
# Coding : 628000049301
ASAM: UDS, EV_SunRoofCONTIAU736 006008
DATASET: 8W2909469C
Adressword : CF (Control Unit Lane Change Assistant 2} - J770 MRR1Rear
VAG no. : SW: 4M0907590D HW: 4M0907590
SW version : 0410
# Coding : 1E8002
ASAM: UDS, EV_RearRadarS2BoschAU736 001022
DATASET:
Adressword : D6 (Light Control Left 2} - A31 LED1L
VAG no. : SW: 7PP941572AC HW: 7PP941572A
SW version : 0008
# Coding :
ASAM: UDS, EV_LEDModLeftMELCOAU736 001004
DATASET: 8W2909471A
Adressword : D7 (Light Control Right 2} - A27 LED1R
SW version : 0008
# Coding :
ASAM: UDS, EV_LEDModRightMELCOAU736 001004
DATASET: 8W2909472A
VCP Scan 2:
m$Õö¥ºæ™•ˇ áX†Ü†ÜÄч2) êQ-g#ÙÊÊʬ†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇ„
c
†Ü‡2)ÄÑ`k*∏ÊÊÊˇˇˇˇ≤Tahoma&Generated using VCP SYSTEM
www.obd2.pl†Ü†ÜÄÑ@
ˇˇˇˇ≤Tahoma†Ü¿‘ÄÑ@
ˇˇˇˇˇˇˇ≤TahomaAutoscan protocolˇˇˇ@ñê–»x0]ˇˇˇˇˇˇˇ≤TahomaWorkshop [email protected]ñ@Ñ»x¿-ÊÊÊˇˇˇˇ≤Tahoma&
Scan date 5/27/2021 10:58:49 PM
@ñÒ»x∞} ˇˇˇˇˇˇˇ≤TahomaCar [email protected]ñø§ »xœøÊÊÊˇˇˇˇ≤Tahoma%VIN
Car type
Reg. Plate no.
Customer
æ
ø§ »xœøÊÊÊˇˇˇˇ≤Tahoma---
@ñÉ»xø
ˇˇˇˇˇˇˇ≤TahomaScan
ñø
»xOQˇˇˇˇˇˇˇ≤Tahoma˚
Adressword : 01
Name : Engine Control Module 1
VAG no. : 04L906026AG
Description : J623 R4 2.0l TDI
SW version : 9970
Comm.mode : UDS, EV_ECM20TDI01104L906026AG 005010
HW: 04L907309L
DataSet:
@ñOQ»xÔ›ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñÔ›»xèjÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñèj»xü“ˇˇˇˇˇˇˇ≤Tahomao
Adressword : 02
Name : Transmission Control Module
VAG no. : 8W2927155BD
Description : J217 0CL 20TDIRdW
SW version : 0001
Coding : 000001
Comm.mode : UDS, EV_TCMDL382021 002027
HW: 0CJ927156
DataSet:
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
@ñü“»x?_ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ?_»xflÎÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñflλxo-&ˇˇˇˇˇˇˇ≤Tahoma
Adressword : 03
VAG no. : 8W0907379K
Description : J104 ESP9 Plus
SW version : 0766
Comm.mode : UDS, EV_ESP9BOSCHCMP 002013
HW: 8W0907379J
DataSet: 8W2909504D
@ño-&»x∫&ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ∫&»xØF'ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :1 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤Tahomaáí†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇx ¯†Ü‡2)ÄÑ`k*∏ÊÊÊˇˇˇˇ≤Tahoma&Generated using VCP SYSTEM
[email protected]ñ†ÜÄÑp(ˇˇˇˇˇˇˇ≤Tahoma
Adressword : 08
Name : Air Conditioning
VAG no. : 8W0820043T
Description : E87 Klima Zone 3
SW version : 0210
Comm.mode : UDS, EV_AirCondiBHTCAU491 001013
HW: 8W0820043T
DataSet: -----------
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
@ñp(Äѵˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñµÄÑ∞AÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ∞AÄц)ˇˇˇˇˇˇˇ≤Tahoma"
Adressword : 09
Name : Central Electrics
VAG no. : 8W0907063CG
Description : J519 BCM1 MLBevo
SW version : 0267
Comm.mode : UDS, EV_BCM1BOSCHAU736 018006
HW: 8W0907063BG
DataSet: 8W2909514E
Coding : 5FC7F7
Coding : 02005D
Coding : N/A
Coding : 030000
Coding : N/A
Coding : 1E0500
Coding : 120500
Coding : 000000
@wêo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :2 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤Tahoma¬ë†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇß'†Ü‡2)ÄÑ`k*∏ÊÊÊˇˇˇˇ≤Tahoma&Generated using VCP SYSTEM
[email protected]ñ†ÜÄÑòˇˇˇˇˇˇˇ≤Tahoma
@ñòÄÑ∞$ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ∞$ÄÑP±ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñP±Äц∆ ˇˇˇˇˇˇˇ≤Tahoma
Adressword : 15
VAG no. : 8W0959655F
Description : J234 Airbag10.44
SW version : 0106
Comm.mode : UDS, EV_AirbaAU10BPAAU736 006015
HW: 8W0959655F
DataSet: 8W2909602AC
Coding : 88001B
Coding : 88001B
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
@ñ†∆ ÄÑ@S!ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ@S!Äчfl!ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :3 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤Tahomaí))†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇ@
¿ †Ü‡2)ÄÑ`k*∏ÊÊÊˇˇˇˇ≤Tahoma&Generated using VCP SYSTEM
[email protected]ñ†ÜÄÑ0»ˇˇˇˇˇˇˇ≤Tahoma·
Adressword : 16
Name : Steering Column Electronics
VAG no. : 4M0907129HN
Description : J527 Lenks.Modul
SW version : 0009
Coding :
Comm.mode : UDS, EV_SMLSKLOAU736 006008
HW: 4M0907129HN
DataSet:
@ñ0»ÄÑ–Tˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ–TÄÑp·ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñp·ÄÑ#ˇˇˇˇˇˇˇ≤Tahoma
Adressword : 17
VAG no. : 8W6920771A
Description : J285 TDIeRDW
SW version : 0629
Comm.mode : UDS, EV_DashBoardAU736 001027
HW: 8W6920771A
@ñ#ÄÑ†Øˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ†ØÄÑ@<ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ@<ÄÑ–}ˇˇˇˇˇˇˇ≤Tahoma˘
Adressword : 18
Name : Auxiliary Parking Heater
VAG no. : 4M0265105E
Description : J364 HSG
SW version : 0090
Coding : 0D0F01
Comm.mode : UDS, EV_AuxilParkHeateEBEAU736 001016
HW: 4M0265105E
DataSet: 8W2909858C
@ñ–}ÄÑp
@ñp
ÄÑóÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñóÄÑ ˇ!ˇˇˇˇˇˇˇ≤Tahoma”
Adressword : 19
VAG no. : 8W5907468E
Description : J533 Gateway
SW version : 0118
Comm.mode : UDS, EV_CGateCONTIAU491 003092
HW: 8W5907468E
DataSet: 8W2909515C
Coding : N/A
Coding : N/A
@ñ ˇ!ÄÑ¿ã"ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ¿ã"ÄÑ`#ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :4 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤TahomaëŒ4†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇMÕ
[email protected]ñ†ÜÄÑ0»ˇˇˇˇˇˇˇ≤TahomaÂ
Adressword : 29
Name : Light Control Left
VAG no. : 4M0907397AB
Description : J1018 LCM_MLBevo
SW version : 0024
Coding :
Comm.mode : UDS, EV_LCMLeftHELLAAU736 001012
HW: 4M0907397B
DataSet: 8W2909519B
@ñ–TÄÑp·ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñp·ÄÑ#ˇˇˇˇˇˇˇ≤TahomaÁ
Adressword : 39
Name : Light Control Right
Description : J1023 LCM_MLBevo
SW version : 0024
Coding :
Comm.mode : UDS, EV_LCMRightHELLAAU736 001012
HW: 4M0907397B
DataSet: 8W2909520B
@ñ†ØÄÑ@<ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ@<ÄÑ–}ˇˇˇˇˇˇˇ≤Tahomaı
Adressword : 3C
Name : Lane Change Assistant
VAG no. : 4M0907566D
Description : J769 MRR1Rear
SW version : 0410
Coding : 1E8002
Comm.mode : UDS, EV_RearRadarS1BoschAU736 001022
HW: 4M0907566
DataSet: 8W2909535B
@ñ–}ÄÑp
@ñp
ÄÑóÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñóÄцÿˇˇˇˇˇˇˇ≤Tahoma
Adressword : 42
Name : Door Electronics Driver Side
VAG no. : 4M0959793H
Description : J386 TSG FS
SW version : 0131
Comm.mode : UDS, EV_DCU2DriveSideMAXHCONT 001005
HW: 4M0959793F
DataSet: 8W2909872D
@ñ†ÿÄÑ@eˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ@eÄчÒÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ‡ÒÄÑp3%ˇˇˇˇˇˇˇ≤Tahoma
Adressword : 44
Name : Steering Assistance
VAG no. : 8W0909144H
Description : J500 EPS_MLBEVO_ZF
SW version : 0410
Comm.mode : UDS, EV_EPSZFAU49X 003023
HW: 8W0909144B
DataSet: 8W2909852P
@ñp3%ÄÑ¿%ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ¿%ÄÑ∞L&ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :5 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤Tahoma))ç@†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇgÁ
[email protected]ñ†ÜÄÑ∞Óˇˇˇˇˇˇˇ≤Tahomafi
Adressword : 46
Name : Central Module Comfort System
VAG no. : 8W0907064DC
Description : J393 BCM2 MLBevo
SW version : 0366
Comm.mode : UDS, EV_BCM2HellaAU736 013013
HW: 8W0907064DC
DataSet: 8W2909501D
Coding : N/A
N/A SW: N/A HW: N/A
Coding : 000000
@ñ∞ÓÄÑP{ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñP{ÄÑ
ÄÑÄIˇˇˇˇˇˇˇ≤Tahoma
Adressword : 52
Name : Door Electronics Passenger Side
VAG no. : 4M0959792H
Description : J387 TSG BFS
SW version : 0131
Comm.mode : UDS, EV_DCU2PasseSideMAXHCONT 001005
HW: 4M0959792F
DataSet: 8W2909873D
@ñÄIÄÑ ÷ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ ÷ÄÑ¿bÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ¿bÄÑ–'ˇˇˇˇˇˇˇ≤TahomaH
Adressword : 5F
Name : Information Control Unit 1
VAG no. : 8W0035183G
Description : J794 MU-HS-N-EU
SW version : 0213
Comm.mode : UDS, EV_MUHigScl6C3DELP 001011
HW: 8W0035183A
DataSet: 8W2909545N
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
@ñ–'ÄÑp§'ˇˇˇˇˇˇˇ≤TahomaErrors [email protected]ñp§'ÄÑ‹(ˇˇˇˇˇˇˇ≤Tahoma]000613 (B201A00) Check Software Version Management (SVM) (Check software version management)
@ñ‹(ÄÑ|ú(ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :6 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤TahomaŒ4>L†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇYŸ
[email protected]ñ†ÜÄÑ0»ˇˇˇˇˇˇˇ≤Tahoma˙
Adressword : 69
VAG no. : 4M0907383F
Description : J345 Anhaenger
SW version : 0253
Comm.mode : UDS, EV_TrailFunctGener2Hella 001008
HW: 4M0907383B
DataSet: 8W2909527A
Adressword : 6C
Name : Camera System Rear View
VAG no. : 4M0980556A
Description : J772 RVC Compact
SW version : 0250
Comm.mode : UDS, EV_CamSysRVRVCPANAMLBEv 005010
HW: 4M0980556A
DataSet: 8W2909460C
@ñ†ØÄÑ@<ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ@<ÄÑ–}ˇˇˇˇˇˇˇ≤TahomaÔ
Adressword : 6D
Name : Deck Lid Control Unit
VAG no. : 8W8959107B
Description : J605 HDSG-Modul
SW version : 0163
Coding : 06B0
Comm.mode : UDS, EV_DeckLidCONTIAU736 001015
HW: 8W8959107
DataSet: 8W2909541B
@ñ–}ÄÑp
@ñp
ÄÑóÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñóÄцÿˇˇˇˇˇˇˇ≤Tahoma©
Adressword : 7E
Name : Dash Board Display Unit
VAG no. :
Description :
SW version :
Coding :
Comm.mode : Communication error.
HW:
DataSet:
@ñ†ÿÄÑ@eˇˇˇˇˇˇˇ≤TahomaErrors [email protected]ñ@eÄѨ–ˇˇˇˇˇˇˇ≤Tahoma
@ñ¨–ÄÑL]ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñL]ÄÑ‹û%ˇˇˇˇˇˇˇ≤TahomaÌ
Adressword : 81
Name : Gear Shift Control Module
VAG no. : 8W1713041G
Description : J587 GSM-LL
SW version : 0077
Coding :
Comm.mode : UDS, EV_GSMWaehlZFAU736 001017
HW: 8W1713041J
@ñ‹û%ÄÑ|+&ˇˇˇˇˇˇˇ≤TahomaNo faults found
@ñ|+&ÄÑ∏&ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :7 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤Tahomaç@X†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇÅ†Ü‡2)ÄÑ`k*∏ÊÊÊˇˇˇˇ≤Tahoma&Generated using VCP SYSTEM
[email protected]ñ†ÜÄÑ0»ˇˇˇˇˇˇˇ≤Tahoma)
Adressword : A5
Name : Front Sensors Driver Assistance System
VAG no. : 8W6907217A
Description : R242 BVS
SW version : 0050
Comm.mode : UDS, EV_BVSMLBevKOSTAAU736 002026
HW: 8W6907217A
DataSet: 8W2909466C
@ñ–TÄÑp·ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñp·ÄÑ#ˇˇˇˇˇˇˇ≤TahomaË
Adressword : AC
Name : Reductant Control Module
VAG no. : 4M0907355D
Description : J880 SCR-Stg-G3
SW version : 0006
Coding :
Comm.mode : UDS, EV_RDCMINERGAU736 005012
HW: 4M0907355B
DataSet: 8W2909571D
@ñ†ØÄÑ@<ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ@<ÄÑ–}ˇˇˇˇˇˇˇ≤Tahoma¸
Adressword : CA
Name : Control Module For Sunroof
VAG no. : 4M0907594J
Description : J245 SAD_STG_1
SW version : 0005
Comm.mode : UDS, EV_SunRoofCONTIAU736 006008
HW: 4M0907594
DataSet: 8W2909469C
@ñ–}ÄÑp
@ñp
ÄÑóÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñóÄцÿˇˇˇˇˇˇˇ≤Tahoma˘
Adressword : CF
Name : Control Unit Lane Change Assistant 2
VAG no. : 4M0907590D
Description : J770 MRR1Rear
SW version : 0410
Coding : 1E8002
Comm.mode : UDS, EV_RearRadarS2BoschAU736 001022
HW: 4M0907590
DataSet:
@ñ@eÄчÒÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]ñ‡ÒÄÑp3%ˇˇˇˇˇˇˇ≤TahomaÌ
Adressword : D6
Name : Light Control Left 2
VAG no. : 7PP941572AC
Description : A31 LED1L
SW version : 0008
Coding :
Comm.mode : UDS, EV_LEDModLeftMELCOAU736 001004
HW: 7PP941572A
DataSet: 8W2909471A
@ñ¿%ÄÑ∞L&ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :8 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤Tahoma>L†Ü†ÜÄч2)†Ü†ÜÄч2) êQ-ˇˇˇˇ}˝†Ü‡2)ÄÑ`k*∏ÊÊÊˇˇˇˇ≤Tahoma&Generated using VCP SYSTEM
[email protected]ñ†ÜÄÑ0»ˇˇˇˇˇˇˇ≤TahomaÔ
Adressword : D7
Name : Light Control Right 2
Description : A27 LED1R
SW version : 0008
Coding :
Comm.mode : UDS, EV_LEDModRightMELCOAU736 001004
HW: 7PP941572A
DataSet: 8W2909472A
@ñ–TÄÑp·ÊÊÊˇˇˇˇ≤TahomaECU scanning [email protected]êo(‰£0¸(ˇˇˇˇˇˇˇ≤TahomaPage :9 z 9†Ü†ÜÄч2)∏ˇˇˇˇˇˇˇ≤Tahoma
Thx!
SW version : 9970
DATASET:
****>> No faults found
SW version : 0001
# Coding : 000001
DATASET:
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
SW version : 0766
DATASET: 8W2909504D
SW version : 0210
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
SW version : 0267
DATASET: 8W2909514E
Coding : 5FC7F7
Coding : 02005D
Coding : N/A
Coding : 030000
Coding : N/A
Coding : 1E0500
Coding : 120500
Coding : 000000
SW version : 0106
Coding : 88001B
Coding : 88001B
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
SW version : 0009
# Coding :
DATASET:
SW version : 0629
SW version : 0090
# Coding : 0D0F01
DATASET: 8W2909858C
SW version : 0118
DATASET: 8W2909515C
Coding : N/A
Coding : N/A
SW version : 0024
# Coding :
DATASET: 8W2909519B
SW version : 0024
# Coding :
DATASET: 8W2909520B
SW version : 0410
# Coding : 1E8002
DATASET: 8W2909535B
SW version : 0131
DATASET: 8W2909872D
SW version : 0410
DATASET: 8W2909852P
SW version : 0366
DATASET: 8W2909501D
Coding : N/A
N/A SW: N/A HW: N/A
Coding : 000000
SW version : 0131
DATASET: 8W2909873D
SW version : 0213
DATASET: 8W2909545N
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
000613 (B201A00) Check Software Version Management (SVM) (Check software version management)>> Errors found
SW version : 0253
DATASET: 8W2909527A
SW version : 0250
DATASET: 8W2909460C
SW version : 0163
# Coding : 06B0
DATASET: 8W2909541B
VAG no. : SW: HW:
SW version :
# Coding :
DATASET:
>> Errors found
SW version : 0077
# Coding :
SW version : 0050
DATASET: 8W2909466C
SW version : 0006
# Coding :
DATASET: 8W2909571D
SW version : 0005
DATASET: 8W2909469C
SW version : 0410
# Coding : 1E8002
DATASET:
SW version : 0008
# Coding :
DATASET: 8W2909471A
SW version : 0008
# Coding :
DATASET: 8W2909472A
VCP Scan 2:
c
www.obd2.pl†Ü†ÜÄÑ@
ˇˇˇˇ≤Tahoma†Ü¿‘ÄÑ@
Car type
Reg. Plate no.
Customer
æ
@ñÉ»xø
ˇˇˇˇˇˇˇ≤TahomaScan
»xOQˇˇˇˇˇˇˇ≤Tahoma˚
Adressword : 01
SW version : 9970
HW: 04L907309L
DataSet:
Adressword : 02
SW version : 0001
Coding : 000001
HW: 0CJ927156
DataSet:
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
Adressword : 03
SW version : 0766
HW: 8W0907379J
DataSet: 8W2909504D
Adressword : 08
SW version : 0210
HW: 8W0820043T
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
Adressword : 09
SW version : 0267
HW: 8W0907063BG
DataSet: 8W2909514E
Coding : 5FC7F7
Coding : 02005D
Coding : N/A
Coding : 030000
Coding : N/A
Coding : 1E0500
Coding : 120500
Coding : 000000
Adressword : 15
SW version : 0106
HW: 8W0959655F
Coding : 88001B
Coding : 88001B
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Coding : 2D2D2D
Adressword : 16
SW version : 0009
Coding :
HW: 4M0907129HN
DataSet:
Adressword : 17
SW version : 0629
HW: 8W6920771A
Adressword : 18
SW version : 0090
Coding : 0D0F01
HW: 4M0265105E
DataSet: 8W2909858C
@ñ–}ÄÑp
@ñp
Adressword : 19
SW version : 0118
HW: 8W5907468E
DataSet: 8W2909515C
Coding : N/A
Coding : N/A
Adressword : 29
SW version : 0024
Coding :
HW: 4M0907397B
DataSet: 8W2909519B
Adressword : 39
SW version : 0024
Coding :
HW: 4M0907397B
DataSet: 8W2909520B
Adressword : 3C
SW version : 0410
Coding : 1E8002
HW: 4M0907566
DataSet: 8W2909535B
@ñ–}ÄÑp
@ñp
Adressword : 42
SW version : 0131
HW: 4M0959793F
DataSet: 8W2909872D
Adressword : 44
SW version : 0410
HW: 8W0909144B
DataSet: 8W2909852P
Adressword : 46
SW version : 0366
HW: 8W0907064DC
DataSet: 8W2909501D
Coding : N/A
N/A SW: N/A HW: N/A
Coding : 000000
@ñP{ÄÑ
ÄÑÄIˇˇˇˇˇˇˇ≤Tahoma
Adressword : 52
SW version : 0131
HW: 4M0959792F
DataSet: 8W2909873D
Adressword : 5F
SW version : 0213
HW: 8W0035183A
DataSet: 8W2909545N
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
Coding : N/A
Adressword : 69
SW version : 0253
HW: 4M0907383B
DataSet: 8W2909527A
Adressword : 6C
SW version : 0250
HW: 4M0980556A
DataSet: 8W2909460C
Adressword : 6D
SW version : 0163
Coding : 06B0
HW: 8W8959107
DataSet: 8W2909541B
@ñ–}ÄÑp
@ñp
Adressword : 7E
VAG no. :
Description :
SW version :
Coding :
HW:
DataSet:
Adressword : 81
SW version : 0077
Coding :
HW: 8W1713041J
Adressword : A5
SW version : 0050
HW: 8W6907217A
DataSet: 8W2909466C
Adressword : AC
SW version : 0006
Coding :
HW: 4M0907355B
DataSet: 8W2909571D
Adressword : CA
SW version : 0005
HW: 4M0907594
DataSet: 8W2909469C
@ñ–}ÄÑp
@ñp
Adressword : CF
SW version : 0410
Coding : 1E8002
HW: 4M0907590
DataSet:
Adressword : D6
SW version : 0008
Coding :
HW: 7PP941572A
DataSet: 8W2909471A
Adressword : D7
SW version : 0008
Coding :
HW: 7PP941572A
DataSet: 8W2909472A
Thx!
