661 - 680 of 1,584 Posts
Hi, I used Congo activator and unlocked smartphone interface but my USB is charge only, anyone knows how to change it? I have 8v 2017 A3, i bought this usb 8v0035708.
I didnt find any other post about it, thanks
Hi, ive aplied patch to 2035 and try all 3 version of maps but non of then can be installed, it trys to install but on 25% it breaks and i get this message, do i need to update SW to newer version? There is licence active under 0025
Tryed format it like FAT32 16bit, all the same, i had 25% in one case 33% and then invalid map data, ive used 2.5 activator, after i remove SD card its try to install maps without card and show me message that card is removed and that some functions may be limited. Seems like it stucked in some loop cause every time i start car it shows that SD card is missing. Maybe Congo knows why
Tryed format it like FAT32 16bit, all the same, i had 25% in one case 33% and then invalid map data, ive used 2.5 activator, after i remove SD card its try to install maps without card and show me message that card is removed and that some functions may be limited. Seems like it stucked in some loop cause every time i start car View attachment 186327
you need to code the car with VCDS or OBD11. The Navigation system needs to be set for Europe region after the first time it’s activated. Congo wrote about it clearly in his instruction!
I have successfully updated the 2022/2023 maps exactly following the Congo manual great ! I have A4 B9 2018 with P1240, I've used SD 32 GB FAT 32. No firmware update because it works :).
I also coded the maps on the FIS (no Virtual Cockpit), again following the excellent manual, in the MIB menu the map setting appeared the dashboard map settings, so I guess the coding is ok, unfortunately I don't have the multifunction steering wheel plus with the left buttons, so I can't select in the dashbord Map/Compass/Preference, I only see Compass. Is there any possible coding to recode the steering wheel buttons to look like the buttons I don't have? Are there any other options for me other than installing the new physical buttons?
Thanks in advance.
hello everyone since yesterday I'm reading this post to understand how to unlock the MHS2 navigator on my audi q2 2018. I downloaded the packages - map 2023 - MHS2 AUDI activator - Software MHS2_ER_AU_P2035 - Software update instructions but I don't know what to do and I'm afraid of only doing damage. Could someone kindly explain to me how to do everything step by step?
I add by saying that I don't have a vcds, but only an OBDELEVEN PRO
on the activator zip there is a pdf and it says to insert dlphi.sh in SD_ACT.zip where can I find the "SD_ACT.zip" ?
