41 - 60 of 1,583 Posts
Hello. I have a question for group members, the author of the post. 1 - download activator installs 2 - download maps and update? do i need to update to a newer version? my parameters are:
Current version:
MHS2_EU_AU K0129
MU software:
0159
Registration
00050000
00070200
00030000
00060800
00060900
Author says:
If your MMI is working properly and you have not noticed issues then you can continue using same version.
Believe me, i know these systems inside out.
As you will see bellow the supported versions list is quite long and will only get longer with time!
If Navi isn’t actually activated, you need to code it in 5F, following instructions.
Can someone with maps help me? I downloaded the activator plus maps. I did everything as described in the activator package. everything went smoothly, a green message completed successfully, two new icons appeared - Map - Navigation. I downloaded maps from the link, formatted the fat32 card and threw all the contents of the package on the card, inserted the card in SD1, go to the red menu - Update and I do not see the memory cards. what am I doing wrong, how should I upload maps via SD card? excuse me, I'm a layman, I don't know much.
Kody które wgrałem :
00050000
00070200
00030000
00060800
00060900
00030000
00030001
00040100
00050000
00060100
00060200
00060300
00060400
00060800
00060900
00070200
0230004a
0230004a
0250004a
023 d004a
025d004a
0231004a
0251004a
00050000
00070200
00030000
00060800
00060900
00030000
00030001
00040100
00050000
00060100
00060200
00060300
00060400
00060800
00060900
00070200
0230004a
0230004a
0250004a
023 d004a
025d004a
0231004a
0251004a
p.s. I go to the red menu - update and I don't see the card, I think. how is the card removed and then the card has been withdrawn ...
As stated before: if Navi isn’t actually activated, you need to code it in 5F, following instructions on page 6.
You have to buy at least a OBD11,VCDS device to code the appropriate byte/bit in 5F, or find someone that can do that for you. Maps on MHS2 are read directly from SD, no need to install anything.
If all are maked "legal", the license codes seems correct to me:
"00030000" # AMI
"00030001" # Gracenote
"00040100" # Navigation
"00050000" # Bluetooth
"00060200" # Audi Connect
"00060700" # Online Services
"00060800" # Apple CarPlay
"00060900" # Google AndroidAuto
"00060a00" # Baidu CarLife iOS
"00060b00" # Baidu CarLife Android
"00070200" # SDS for Nav Systems
"00070400" # Electronic Driver Voice Amplifier
"025x00xx" # Audi MIB-HS NavDB
"023x00xx" # Audi MIB-HS NavDB
Thank you, you brightened me up. I thought that in 5F I will come with cards with maps through updates. I understand that the navigation was not activated from the beginning of the car leaving the salan, so you need to activate it by 5F? when buying a device, I do not know if it will be cheaper, better if someone does it to me and it hurts. I thought that everything can be done via an SD card. p.s. if I upload maps, navigation to read Navigations on the display between 7-inch clocks?
I bought a used one, it has two USB and two SD card slots plus Aux. CarPlay works, but my dad drives the car and has poor eyesight. he wants to embrace the navigation, it is best if it is also displayed on the FIS 7 inch (the display is smaller next to the watch, the steering wheel)
Discussion starter · #57 ·
The map of MHS2/MST2(soon to be released) is not installed, you copy map on SD and just insert in the unit.
If coding is ok and fecs are shown as valid then map will work.
Simple as that :)
With next release i will extend the validity of the map ... seems 2030 is just around the corner for some users ;)
Regards.
Discussion starter · #60 ·
Your version seems to be newer than 129 but still way older than latest available.
Because of that the process of update is not that simple, there are cases where users fail with that update and then the MMI does not work properly or at all.
You can always try to update or find someone that is experienced enough with those kind of MMIs and remove the risk form you.
Regards.
