201 - 220 of 1,588 Posts
yes,
you can use it, last one v2.1 , I have use it on a VW Sportsvan(2018) with MST2_EU_VW_P0876D FW MU ver: 0876 HW: 851 ... D are Delphi
working fine!
Navi maps working now on any SD card last ones downloaded directly app-connect.volkswagen mapupdate page and Android Auto working now too
1st page Spoiler: Activator MST2 VW
when its done check by your pc the log.txt on the sd, so you can read what was done
yes,
working fine!
Than you friend, i will try later.
How long the process of patching takes?
Might be silly question
MSH2_ER_AU_P0463, MU 0170
Nav already enabled as an option with a 2500018 code in the list
Ran activator without issues, removed SD card after green complete screen and screen closed
Plugged in new SD card with the 2022/2023 maps from the mega download
Get the Navigation date are invalid after 25%, org Audi 2017 SD card works fine
Can see extra codes on the license screen so presume update worked
Log file has no errors
Would it be the maps download or the original 2018 license code still taking precedence?
Not a huge issue as tend to use CarPlay anyway but nice to have up to date maps, am downloading the 2022 ones to try as well (just taking some time as can't refresh my ip).
BTW thanks for this thread for highlighting the 2035 f/w swaps maps providers out and then needs Audi Connect! saved me causing myself an issue :)
blades69
Don't use a mac for transferring files to SD. Some hidden files cause disruptions on filesystem
starts reading the navigation system up to 25%. Then it says "the navigation data is not valid"
maybe its your SD card not (well FAT32), do not use micro sd cards!
its an card issue or your download are non ok!
solution: your save the original sd card files on your pc and then delete the content and write the 2022/2023 maps on it,
then you will know sd card or download maps issue
read carefully the MST2_Activator pdf, if I remember well was fast about 5-8 min. with the reboots.
Im reading the pdf file, but im not sure which activator to use, one is "v2 Lazarus" another is "pre v2.1 VIN BUG"
And one more question, about FEC, how to know if my unit has FEC or valid FEC
Thank you again
No precedence in FEC codes, if you have the new licenses in legal status, the only problem is on map SD.
22/23 link is valid i use it on my car. Format SD on FAT32, optionally use a fast card for better experience (like sandisk gold, not more) and DO NOT USE A MAC for copying files from downloaded archive to sd card.
Should be work.
Should be work.
FAT32 format seemed to be the solution for me, might have been the fact I used a Mac originally but I quick fomatted as exFat and had the issue, full FAT32 format and copied over files - worked a treat.
Thanks for the replies and help
Thank you again
1. before starting, push for some seconds button Menue, its appearing the Service Menue screen, go to Function Enabling Codes and make from all pictures for later, so you can check!!
I send you an youtube link on conversation/message, so you can see what I mean!
2. load on an empty SD card (FAT32) with an windows PC the activator 2.1 (my recommentation)
3 after all done, make again 1. step to control your Function Enabling Codes situation now!! what was on NON activated you will see its now Activated!.
here an extract of my log.txt that was greatet by congo activator on the sd card:
EL list created successfully.
Adding 00030000 to FEC list.
Adding 00040100 to FEC list.
Adding 00050000 to FEC list.
Adding 00060100 to FEC list.
Adding 00060200 to FEC list.
Adding 00060300 to FEC list.
Adding 00060400 to FEC list.
Adding 00060800 to FEC list.
Adding 00060900 to FEC list.
Adding 00070100 to FEC list.
Adding 00070200 to FEC list.
Adding 00070400 to FEC list.
Adding 09400008 to FEC list.
Adding 09410008 to FEC list.
Adding 094D0008 to FEC list.
Adding 094200ee to FEC list.
Its really simple, to say, with activator only the FEC that your car/MMI has can be activated,
all other you will need OBD11 or other tools to patch it here:
congo said:
It is never mentioned anything like green menu.
You need OBD11/VCP/VCDS/Odis E
Thank you alex, i think i can try😀
This is it!
The proper activator for Audi MHS2 systems made by delphi.
It a result of deep system analysis and some good reverse engineering.
The time has come and i have decided to share it!
Now is available free of charge for everyone!
Unlike the leaked version of the activator this one is tested and in use for quite long time now.
You will not loose ability to install custom POI's and for sure it will not cripple your legal function enabling codes.
I cannot guarantee that will work on every MMI out there, but i never had issues ever since i created it back in 2016.
Regardless of what some might say, update of the MMI is not mandatory. This is entirely up to you.
If your MMI is working properly and you have not noticed issues then you can continue using same version.
Believe me, i know these systems inside out.
As you will see bellow the supported versions list is quite long and will only get longer with time!
In case that you do decide to update then subscribe to this topic as i will update it to include software update info and files.
In the archive you will find a manual how to use it.
It is very simple process and you will only need one empty SD card size 8-32GB FAT32 formatted.
After activating the MMI you will be able to use latest navigation maps.
Here is list of supported versions, it was tested on many more but for now i decided to include the following.
If your software is not the support list then send the backup that the activator will make and i will add it. Always make sure you are using the latest version of the activator.
Almost any version out there!
If for some reason you cant get it to work following the manual then its likely that your unit was already patched.
In such case contact me and i will see what i can do about it.
Please have in mind that im doing this in my free time and that means that im not 24/7 available :)
The map of MHS2/MST2(soon to be released) is not installed, you copy map on SD and just insert in the unit. If coding is ok and fecs are shown as valid then map will work.
Simple as that :)
MAP 2022/2023 -> 11.64 GB file on MEGA
MHS2_ER_AU_K0129 -> 2.09 GB file on MEGA
MHS2_ER_AU_K0471 -> 2.53 GB file on MEGA
MHS2_ER_AU_P1242 -> 2.55 GB file on MEGA
MHS2_ER_AU_P2035 -> 2.54 GB file on MEGA
MHS2_US_AU_K0471 -> 1.02 GB file on MEGA
MHS2_US_AU_P1242 -> 1.01 GB file on MEGA
MHS2_US_AU_P2037 -> 1.02 GB file on MEGA
Software update instruction -> 720.9 KB file on MEGA
This document and activation are provided by THE PROVIDER "as is" and "with all faults." THE PROVIDER makes no representations or warranties of any kind concerning the safety, suitability, lack of viruses, inaccuracies, typographical errors, or other harmful components of this document. There are inherent dangers in the use of any software, and you are solely responsible for determining whether the procedure described in this document is compatible with your equipment and other software installed on your equipment. You are also solely responsible for the protection of your equipment and backup of your data, and THE PROVIDER will not be liable for any damages you may suffer in connection with using the information found in this document. You are also solely responsible for any modifications to the software of the MMI system, THE PROVIDER will not be liable for any claims from the vendor of your MMI system concerning the use of third-party software on the MMI system.
Selling this document and activation is forbidden.
Including this activation or its parts in any other tools should happen only after contacting me.
Attempts to modify the files might render the system inoperable.
Enjoy :)
This is it!
Simple as that :)
Enjoy :)
This is it!
Simple as that :)
Enjoy :)
Hi can anyone tell me which software version I need to d/l. Newbie here I'll try and post a pic of my current version. Thanks all
It should be:
MHS2_ER_AU_P2035_MU235
You can have a look at:
But it's only German .
Hi can anyone tell me which software version I need to d/l. Newbie here I'll try and post a pic of my current version. Thanks all View attachment 184563
You dont need an FW update if all works fine, only congo activator !
