121 - 140 of 1,588 Posts
I read the instructions. but my English is not very good. So I prefer to make sure that you only need to upload these three files and do it all so as not to spoil anything
Did the activation and after that the new maps worked brilliantly on my A4 B9 from 2018 (MHS2_ER_AU_P1242 with 0213), thanks for all the effort!
Also want to confirm that I was able to get the maps shows on the dashboard screen with the instructions for the activator manual and using the OBDELEVEN dingle and software
Unfortunately, activator doesn't work for me. Tried several times with 2.2 and 2.3 ver. but nothing changed. No green or red screen just keeps restarting until i remove SD card. Will try to update SW to MHS2_ER_AU_P2035 from 1242 and try again.
Discussion starter · #132 ·
There must be a log on the SD.
Also define "nothing changed", what you expect to change ?
The fact that it did worked for a lot of people means that the problem is in your unit or in the expected result.
Guys, w/o logs dont even bother to write - i dont have crystal ball.
p.s. looking at what you write - the SD is locked - it will never work this way!
Maybe i will add that in next release to not start at all. But its a common sense to leave the SD unlocked rather than locking it!
Hi Congo,
Wow, perfect job. I will try later on my best friend A4 with MHS2_ER_AU_P1242 where we need only to update maps (they are already active but outdated)
Reading the documentation I don't understand how i can start maps update. In my Q2 with Harman unit patched i need to go to Settings > Update. Is the same or i need to wait and the update starts immediatly?
Furthermore the file-system for maps update remains FAT32 as the Activator? n my Q2 with Harman unit patched this step requires an exFat formatted SD..that's why i'm asking.
Thanks you so much, really appreaciated your job!
Antonio
Dont know how it is possible but card was locked. I didnt think about this cos 1 minute earlier i formated it and copied activator on it so for sure card was unlocked. Now it works perfectly. Thank you Congo for reply and all your work.
Antonio
Hey Antonio to update maps on patched Delphi unit (MHS) you just need to copy newest maps on SD card and insert it to 1st slot. There is no installation process. Harman has a hard disk so installation is needed but Delphi doesnt have hard drive.
Hello, my Audi A4 2016 current firmware is MHS2_EU_AU_P0114. Which ones do i need to download to update the firmware to the latest? Also after firmware update, would I lose any coding I did with the OBDEleven?
Updated with 2.3 and the 2022 maps work fine but the 2022/23 maps don't for some reason. The only thing i can see thats different between the 22 maps and the 22/23 maps is the cid file in the 22 maps
