281 - 297 of 297 Posts
or without need of actual maps, using AppConnect (activated after using congo activator) then with Carplay or Android Auto,
works also great with the Google Maps
Thanks for helping the screen shot. Also it'll take a while even with good speeds. Best idea is to use a download manager.
Thank you for the activator. I have an Audi Q5 with MHS2_ER_AU_P2035. The activator (2.3) worked for me, and I can use the new maps too. I want to use android auto and I bought a ODBeleven, but I see now I have only charge only interface. Can I use android auto any way in my car?
Hi Thomas, question reg: Android Auto.
Automotive lighting Automotive design Font Display device Auto part
My 2018 Audi Coupe uses (see above) & I have just installed the CONGO ACTIVATOR & I now have navigation.
I would also like to use Android Auto + WAZE for local maps (Portugal).
How do I UPDATE the USB interface you make mention of above? Can you please post up URL for a tutorial?
Sincere thanks.
just install the CONGO ACTIVATOR, then if hardware missing see here the video how to do
you need the cable(because of data connection/connector) today your usb are only charging! and
you need this 1x usb interface because inside they have the chip for data (license) inside!
costs:
HI EVERYONE! First of all I want to thank @congo for the magnificent work with the activator for Delphi, I have managed to unlock the car navigator in my audi a3 8v with version MHS2_ER_AU_P2035 working with maps 22 those of 22/23 I have not succeeded yet but I am very happy, I just want to ask a couple of questions that I have, first is how I can add POIs to MYAUDI special destinations to add fixed speed cameras (here in Spain it is totally legal) and second if there are some more functions that I can activate, to What use are the software applications and because now the OPS system does not appear on the screen when I approach an obstacle with Drive gear, in Reverse it always appears together with the reversing camera, thank you very much and best regards.
hi willfa69
1. more function depends on your MMI what FEC they support(check it out), FEC code list
Font Gas Multimedia Display device Personal luxury car
FEC Codes
00030000 - AMI (USB)
00030001 - Gracenote
00040100 - Navigation
00050000 - Bluetooth
00060100 - Vehicle Data Interface
00060200 - AudiConnect / VW CarNet
00060300 - MirrorLink
00060400 - Performance Monitor
00060500 - Porsche SportChrono
00060600 - Porsche Logbook
00060700 - Porsche Mobile Online Dienste
00060800 - Apple CarPlay
00060900 - Google AndroidAuto
00060A00 - Porsche RaceApp
00060B00 - Baidu CarLife
00060F00 - DAB full
00070100 - VoiceControl (SDS)
00070200 - VoiceControl (SDS with Nav)
00070300 - VoiceControl (Online SDS with Nav)
00070400 - Electronic Voice Amplifier (ICC)
07400008 - Maps Seat MIB2 Std Eu Lifetime
08400008 - Maps Skoda MIB2 Std Eu Lifetime
09400008 - Maps VW MIB2 Std Eu Lifetime
094000FF - Maps Discover Pro Lifetime
0C400008 - Maps MAN MIB2 Std Eu
07410008 - Maps Seat MIB2 Std NAR
08410008 - Maps Skoda MIB2 Std NAR
09410008 - Maps VW MIB2 Std NAR
0C410008 - Maps MAN MIB2 Std NAR
2.
  • speed stationary
  • Speed mobile (up-to-dateness = the last 3 years)
  • Traffic light and speed
  • Traffic light
  • distance mobile
  • Section stationary
compatible with:
Audi A3/RS3 (8V)
MMI® navigation plus with MMI® touch (4G)
MMI® Navigation (Facelift 2016 Update TPI 2045974)
Audi A4 (B9)
MMI® navigation / MMI® navigation plus with MMI® touch (4G)
Audi A5 (from MY 2017)
Audi A6 (C7 from MY2015)
Audi A7 (from MY2015)
Audi TT (from MY2015)
Audi Q2 (from MY2016)
MMI® navigation (if update to version 0192 required before week 45/2016)
Audi Q5 (from MY2017)
Audi Q7 (from MY2015)
Audi R8 (from MY2016)
Installation:
Copy downloaded content to SD card (FAT32).
Insert the SD card into the Audi MMI.
Variant 1: In the menu (press the MENU button), select "Settings", "MMI settings", "System update" or system maintenance, then "System update".
Variant 2: Press the MENU button, select the "Audi Connect" option, "Software Update", "Start map update now".
Variant 3 (Audi Q5): Press the MENU button, select the "Navigation" option, press the control knob to the left, select "Points of Interest". Scroll to "My Audi POIs" and press the control knob to the right, "Import My Audi POIs".
Select the correct storage medium.
The update is now recognized and the POIs and speed cameras can be transferred.
Installation Video:
3.
Vehicle Car Plant Satellite radio Vehicle audio
Hi Everyone, thank you very much Congo for your instructions on how to activate the maps in the MMI. However, in my case it is that I only have a "Charge only" USB port in my AUDI A4 2017 car. I wanted to ask if even with such a configuration I will be able to install the maps according to your instructions. I don't understand what exactly the sentence in your instructions means "If you have the Charge only one then Smartphone interface will not work. You need to change the AMI interface and install the required wiring."
Does this mean that the maps will work, but some others will not?
Thanks for the reply.
what firmware you have actual? check it via using red menu
You need to change the AMI interface and install the required wiring." see also here
Thats for having the Android Auto or Carplay working after use of congo activator, so its for this wish!
In your case maps, that will work!
