Thanks for advice. It's Delphi, but Composition Media. For Audi, the rule is not to try if there are not 2 SD slots, that's why I asked the questionimportant are MST2 .....D on the end, check firmware (menue bottom for 5sec, then read your fw) , then its an Delphi unit
test it, if it works you will find the result on your sd card in the log.txt, also if its not working for your unit
P0890Dwich firmware it has?
Thank you!so its the fw MST2_EU_VW_P0890D, then use it
Awesome thanks so much
Mibsolution.oneHello @Region rat where are you getting your US maps ?
Mibsolution.one
