Don't use Mac for maps.
Hi,First - it is not good idea to just install patches w/o reading the info posted here.
If you used version older than 2.3 its recommended to install this one.
Second - other users had same issue map stuck at 25% just 2-3 pages back ... do we have to read and point every time the same? Check what others did to solve the issue. Its 100% SD card issue.
Yes, of course. Not even for unzipping the files. All of the operations must be done on a Windows PC.Don't use Mac for maps.
Hi @john.player,Why 16kb cluster size?? What are the improvements?
16Kb should be the default cluster size for FAT32 and 16-32Gb SDHC
Hello mate,Hi congo, i just updated from MHS2_EU_AU_P0114 to MHS2_ER_AU_K0129 but when i will update the next available Firmware on the first page after reading Metadata undefines Error 14 comes up. i will need a Firmware to update to K04 and then to P20xx is there a solution /Firmware ?
really an old version your unit has MHS2_EU_AU_P0114, maybe the maps here will not work for your unit, maybe not even the activator, only your test can show it and check later the log.txt file of the sd card used for itHello mate,
Did you manage to update to K0129?
Did you have to run any patches or a straight forward update?
