1 - 2 of 2 Posts
The issue I've had with my 2010 A5 (106000 miles) is many. Numerous codes and will list in a moment.
Some symptoms are as follows:
1, Every morning I start my car it is very rough on the idle
2, changed numerous items on car
O2, high pressure pump, pressure sensor, map and maf, cam shaft sensor, alternator, plugs and coil packs. Ordered a new fuel pump that's yet to arrive.
Some codes I get:
TPMS, ABS, Too lean, Too rich, Maf sensor.
I'm at my wit's end with this car.. Any help would be appreciated!
Discussion Starter #2
A better list of said codes:
OBD2:
P2177 (confirmed) - System Too Lean Off Idle Bank 1
P0130 (pending) - O2 Sensor Circuit Bank 1 Sensor 1
P2177 (permanent) - System Too Lean Off Idle Bank 1
Body/convenience system:
01518 - Bulb for Back-Up Lights, Left (M16)
Parking brake:
01314 - Engine Control Module (ECM)
ABS:
00473 - Control Module for Electric Park- / Hand Brake (J540)
Engine:
04698
02821
07670
1 - 2 of 2 Posts
