1 - 8 of 8 Posts
So, after missing the car for 2 weeks (due to the deer running in front of me) They did amazing job on the body work (new hood left fender) and painted it and it matches beautifully...
I was turned the tires hard left while doing a 3 point turn and I hear a weird sound of metal.. and said.. well.. you can problem guess it :eek:
Anyway, whenever the wheels rotate.. scrape ..scrape.. scrape .. So.. tow truck is comming tomorrow early in the AM. I will keep everyone posted.
Any ideas what this might be??
Stone guard on brake disc? It is made of very thin metal and easily distorted.
There's a backing plate to the brake rotor, might be a little bit bent from your accident, could possibly cause noises like that.
Cars will never be the same after theyve been crashed
Discussion Starter · #6 ·
The crash was all cosmetic luckily except for cracking the plastic protector for the light which caused the light to burn out. They said the hood was "moved" about 1/2 mm and the fender was bent by an inch. This noise didn't start happening until I moved the wheel all the way pointing hard right (my bad for saying left up there)
Fixed
Easy fix. A heat sheild came lose due to the mechanic working on it when painting the car and was laying on the axle on that side.
Lewy, I was gonna guess deer foot in hub. lol Glad it wasn't that.
1 - 8 of 8 Posts
