KW Variant 2 Coilovers for S5
26585 Views 91 Replies 27 Participants Last post by  wwhan
S5 - KW Coilovers – Variant 2 Initial Review
A few of you will be aware Doubledoom and I had the KW variant 2 coilovers fitted to our S5s by the guys at APS today, the first to have them fitted in the UK apparently. After a 140 mile trip back home here are my initial thoughts:
Although I had the car lowered 25mm with the H&R springs about a month ago, this was always a temporary measure until the KWs were available for the S5. The H&Rs gave the car that much sought after lowered look and even better handling characteristics but there was always the compromise of a harsh ride when compared to stock. For me this was tolerable but as soon as something came available that could offer the same look but with the ride comfort of the stock set up I would have it. Enter the KWs.
First the look. The ride height is adjustable on the V2s and I opted for a 25mm drop at the front and 20mm at the rear to try and give a dropped front appearance and more aggressive look. The initial set up doesn’t look too different from the 25mm drop all round I had with the H&Rs but over time the springs will bed in and any fine adjustments will be more meaningful, so for the next couple of months this is the ride height I’ll keep. Adjustment of ride height just requires the wheels off to enable access. The rebound was left in the default comfort set up. Adjusting this is a little more involved and requires the units to be detached at the top.
An initial test drive around the industrial estate near to APS took me over a few minor pot holes and bumps and these were despatched without any jolts or thuds in the car at all. The H&Rs definitely reminded you they were a stiffer set up when travelling over such surfaces. The real test, however would be the drive home.
A variety of road conditions were encountered including the following: a series of regular thick lines painted across the road on an approach to roundabouts, cats eyes between lanes, railway crossing, minor pot holes and sleeping policemen. Without exception, the drive over all these surfaces at normal driving speeds was smooth and uncompromised and the default comfort setting of the rebound certainly lived up to its description and all my expectations (and hopes).
Although the trip home was blighted with torrential rain from time to time, the handling characteristics of the car were just as good as with the H&Rs ie the car felt as if it was painted to the road. Cornering at speed offered little detectable body roll.
In summary, the KWs offer exactly what I had hoped for. The aggressive lowered look which can be adjusted to suit relatively easily and the comfort of the stock suspension set up. Don’t get me wrong, the H&Rs are a very cost effective means of getting the desired lowering and the compromise to ride comfort isn’t too bad. However the KWs do give the comfort factor back, albeit at a price.
I’m sure Doubledoom will add his own review when he gets chance. Comparing notes following our respective test drives I’m sure he too will have similarly favourable comments.
I’ll give things a few hundred miles to bed in and then update the review. Hopefully we’ll have some better weather between now and then!
Finally, thanks to Ed and the guys at APS for providing first class service once again.
A few images from the day posted below. It wasn't the weather for outside photos so will post some of the car i) If it ever stops raining in the UK and ii) I've got the car clean (again!).
Suspension part Coil spring Shock absorber Suspension Yellow
Suspension part Auto part Coil spring Suspension Shock absorber
Suspension part Suspension Auto part Yellow Coil spring
Auto part Suspension Suspension part Engine
Auto part Suspension part Suspension Coil spring Vehicle
Land vehicle Alloy wheel Vehicle Tire Wheel
Suspension part Shock absorber Suspension Auto part Tool
Coil spring Suspension part Suspension Auto part Coil
81 - 92 of 92 Posts
Thanks LittleDevil, so I have new design !!! :cheers:
I have played with the rear rebound, now it is 12 clicks (9 before) so more comfortable now, in speed 200 km/h and more, 9 clicks is better (but speed limit here is 130 km/h).
So I call it "city setup". (In 95% I drive in the city)
I find this setup good for highway too, 235 km/h and no problem.
Now I read new KW manual and they recomment 9 clicks front, 12 rear, as I had. :thumbsup:
This year's setup is 9 clicks front, 14 rear, because Milltek hits something in the rear, when the rear shocks are too hard.
I know it looks stupid, but I like to play with these things.
Reactions: 1
Hi guys, you have some more experiance then me with this KWs. I just ordered V.2 for my A5 and im realy unsure what rebound i shuld run. Im going on vacation in summers with the boot full of stuff. Living in Norway and driving Danmark,Germany,Austia,Slovenia,Croatia and Bosnia. I dont want enny problems with the setup. Enny sug. what i shuld make my V2.s?
You can follow my posts.
Anybody run the V3s here? About to order them and would like to know some recommended settings for both daily driving and for track/HPDE use.
Great thread guys :thumbsup: definitely helped clear some things up.
I guess since none of you are adjusting the dampening on the V2, then the V1s are the optimal choice. + I don't plan on adjusting anything but the ride height.
TX, you mention, on one of your posts, that you are going with the V1s, yet you ended up buying the V2s, care to explain why you changed your mind?!
Also, where is the best place to order these KW from Europe? Link?
Try this maybe: http://www.kw-suspensions.eu/int/kw_dealerlocator.php
my biggest concern about getting coilovers on my s5 is what happens if you get a defective or blown out coilover?
i had HKS Hypermax coilovers on my lexus IS350 and the ride was fantastic, but when my rear shock was leaking and clearly defective after only about 12,000 miles... they had to be shipped to japan to have them rebuilt...
so what would happen in this case with the KWs.. will they just send you a new shock or have to rebuild it.. and where are they based out of, and about how long could it take... because it took almost 3 months to send out the shock and have it rebuilt then shipped back from japan... i would up just putting my stock suspension back on and selling the rebuilt coilovers...
i saw some mention about faulty shocks with the first few guys that had them in the UK, but they seem to be in driving distance from the shop, where they just gave them new coilovers.. what would happen in this case because im located in New York in the US and this is my daily driver
KW USA is based out of California, I used to have a contact there but he is no longer with the company. They are extremely responsive to even mundane questions about installation and adjustment, and I strongly believe they'd take care of you if a shock blew out.
Yes, KW USA is in central California, near Fresno;
KW automotive North America, Inc. / 1075 North Avenue / Sanger, CA 93657 / USA
KW automotive North America, Inc. KW Coilover Kit V2 Audi A4 B8 - kw coilover kit v2 - Complete Coilover Kit - Products
81 - 92 of 92 Posts
