Look great Tony,
Now I'm not sure what to do, will need to see some more pics on a red A5/RS5!
Update on lights:-
I'm quite excited about this (unlike my other half!).
The FL bi-xenons plug straight in if you have already got bi-xenons. If you have halogen then you need to get an adaptor such as Kufatec and need to check your central electrics module that it is a later version and has enough pins (another thread on the forum on this) The only thing needed is to code the central electrics module, one simple change of a value, nothing major. All good.
You also need to change the headlight carrier and misc parts to fit them in.
With this worked out the front end conversion can now carry on.
Thankyou to Tony,Tom, Morski and others who helped me out with this.:cheers:
Some pictures below running through various tests, hazards, main lights, indicator
