41 - 44 of 44 Posts
So far I've done:
Machine polish
Facelight LED rear light upgrade, LED rear number plate lights, LED reverse lights
Honeycomb fog grill surrounds
Front speaker upgrade, 12" sub+amp in the rear
FL flat bottom steering wheel
RS5 interior door handles
R8 oil cap
Carbon fibre wing mirror caps
Wrapped the dash trims in satin black
Stainless pedal set
Replaced faulty air quality sensor which was causing a few error codes
Dynamic wing mirror indicators
Hardrace rear ARB
Replaced advanced key sensors
Eibach pro lowering springs
15mm spacers all round
S Line side skirts
S Line front and rear bumpers
Transmission mount insert
LED front fogs
Wrapped the window trim in satin black
Changed gear knob to perforated leather
Stuff on the do list:
I've got three glow plugs which need replaced - the car still runs fine but the mechanic said they're stuck pretty tight so might be a longer job than usual
Paint brake calipers
Wrap the grill - it's peeling badly in a couple of places
hi mate,
wondering how you find the eibach pro springs? I’m looking at lowering my black edition a5 and it’s between the H&R OE springs or the eibach. I’ve got 19” rotors and heard the eibach doesn’t give as much of a drop as the OE?
Discussion Starter · #42 ·
hi mate,
It's been a long time since i researched this but think the H&R might give an extra 5mm or 10mm? The Eibach drop the front slightly more than the rear to get rid of the reverse rake which I don't think the H&R does but i'd need to check.
I'm really happy with the end result on mine, i think if you look at the way the car sits on the springs rather than the amount of drop you get a better idea of what it will look like rather than trying to think in terms of drop. I wouldn't want mine any lower but i'm on 20s and have spacers which gives me a bit less scope too.
Yeah from what I’ve read up - eibach sits nice with 20” but I think on 19” would need the OE. Small part of me thinks f*ck it and get the h&r sport ha!
41 - 44 of 44 Posts
