so my key fob has not worked in awhile and i started getting a bunch of headlight errors, fog light stays on when car is off etc, so i decide to pull the BCM under the dash and lo and behold water starts spilling out. so my question is, what aside from removing component protection on the new module, would i need to do to install it? im sure further programming is needed, am i better off trying to send it in for repair? any advice would be appreciated
Get coding from old unit, remove unit, install repplacement (make sure its exact right partno), copy old coding in new unit and remove CP at dealer. Presto.
Reactions: SimonRoma
· Premium Member
Well said Bass mate. PERSONALLY ultra I would avoid the official network unless you enjoy throwing dosh away, find yourself an independent VAG specialist and see what he can do.
