Has anyone else out there in A5 land had a problem filling their beloved A5? Mine (1.8T) seems to have a problem with petrol regurgitation as it reaches full. The first time I filled it up, the auto cut-off of the fuel nozzle didn't get a chance to trigger in time and god knows how much petrol gushed out under some considerable pressure. I mentioned it to Audi when it went back for a software update and they reckon nothing is wrong- they suggested going slowly as I neared the full mark, which is all good and well if you fill up from fumes and know how much it will take! The last time I filled up, from about a quarter full (trying to miss the daily 2p/litre fuel rise!!!!) it caught me out again and I wasted a whole lot all over the forecourt floor.... The fuel pump was different both times but at the same filling station, and I never had that problem with my A4, which I always filled there.
Expensive way to enjoy your motoring I reckon.:eek:
I've never had that problem. If it's always at the same station, maybe the fuel cutoff is just little too late for the tank on the A5?
Hi Perkman,
This is often caused by not having "breathing" room for the vapor-recovery nozzles at the fuel station. You can _usually_ alleviate the problem by inserting the fuel nozzle all-the-way and then slightly removing it so air can enter under the seal/cover that is around the nozzle tip on most vapor-recovery fuel pumps.
BTW, there have been a few other reports of A5/S5 owners having similar problems. I personally have never experienced the issue on my S5, but I have on the BMW.
Thank-you both for the feedback. Will give it a go next time I fill up. Unfortunately the filling station I usually use is a good lot cheaper per tank than the others in the area so my tight wallet always draws me back there! May just have to take a hit and try another filling station..... or stand like a mug and trickle in the last few litres.:eek:
