1 - 6 of 6 Posts
I know this has been asked before but I'm struggling to find the right answer.
I have just purchased an iPod Touch 16Gb and want to play it through my S5. What do I need to buy to get it working.
I have the Sat Nav and B & O if that helps..
You need the Audi Music Interface (AMI) where the iPod connector is fitted in the glovebox. It also comes with other controls that are mounted on the fascia around the gearstick.
I'm not sure if the whole thing can be retrofitted but I'm sure someone more knowledgeable can confirm.
Ami can be retro fitted.
If you have mmi high (controls around the gear stick) it can be retrofitted from launch
If you have generation 3 radio,you can only retro fit ami if you have the 2009 radio as the software isnt supported in the 2008 unit
1 - 6 of 6 Posts
