1 - 12 of 12 Posts
Hey guys so I’m currently stuck I had a 2010 Audi A5 before and car was amazing I recently upgraded to an S5 with the supercharged 3.0 its a 2014 the car when I got it didn’t like to start at all so naturally I replaced the Hpfp and boom the car starts now BUT only when it’s not at operating temps when the coolant and engine are cooled down when it is at operating temperature it cranks for a little and regenwolk start but dies out almost immediately and I have to do this several times over any advice or anyone know what it could be?
Replacing the HPFP was the natural solution to a starting problem, but now you've got a different starting problem?
Get it plugged into proper diagnostics is the first step.
I already did that there were no codes I tested battery starter and alternator before going for hpfp all of those were fine and because the Hpfp is a pretty common failure on these cars that was my next step it started fine all the time for the first few days then just started struggling on start up when the vehicle was hot
Can you go to the supplier and raise an issue wwith them?
Hiya mate and welcome! Your car is very recent so you SHOULD be able to make this car go. Purchase a VCDS module. How many miles has she?? My technique is very old school ie take a note book and pen and start on page one with date, mileage and what mods you make. Then keep notes so that you can always go back one step if you need to. Also you need a VAG specialist to look after the car, avoid the official stealers unless you have money to throw away!!!
1 - 12 of 12 Posts
