Why would I want to carry two keys?Can't you just use the second key?
In some countries, leaving the Engine running without being in the car is illegal.
You live in Florida, correct? When I lived in Edmonton, and it was -40C, it was common to idle one's car because there was a good chance the block would freeze if you left for any period of time without having the block heater plugged in.There are many reasons, one being I don't want to shut down and start up the car while leaving the car for a few minutes at a time.
Just awesome! We are in debt to such great wisdom on this furom. I loved that answer thoughHere's the procedure:
1) Get into the car and lock the doors using the button in the driver's door.
2) Start the engine in the normal manner
3) Lift the 'boot open' button in the driver's door
4) Climb into the back and lower one half of the split-fold rear seat
5) Exit through the open boot (trunk) and shut the boot (trunk) behind you.
Ta dah!
You are now outside the locked car with the engine running.
Of course, the drawback here is that your keys are locked inside and you have no way of unlocking the car to get in, however you didn't specify this was a requirement!
Priceless! And it would definitely work, although I don't think Rezox would necessarily describe this suggestion as 'constructive'.Here's the procedure:
Ta dah!
Lol - surely if you were going to this effort, it would be easier to open the drivers window before getting out of the car (in the normal way), reaching through the window to hit the lock button, and then press the window up button while quickly removing your arm and shoulder.Here's the procedure:
Ta dah!
Neat idea! ...although I kinda like the idea of people watching you emerge from the boot... it would make a grand entrance!Lol - surely if you were going to this effort, it would be easier to open the drivers window before getting out of the car (in the normal way), reaching through the window to hit the lock button, and then press the window up button while quickly removing your arm and shoulder.
Ok, so the key is still in the car, but its a bit more elegant than Ian's solution![]()
If this were true then remote starter devices would be illegal and banned from being sold and produced.I personally don't care if you leave your engine running for a month straight. It's your gas and car . . .
You incorrectly stated it was not illegal, I was just letting you and other readers on the forum know it is. I just don't like people spreading false information.
'If this were true then remote starter devices would be illegal and banned from being sold and produced.
That being said, I guess there is no solution here.
