Well, it took us long enough, but it looks like I have a solution that works.
The LED festoons that I used to replace the stock license plate festoons can be found at tunerdomes.com here:
http://www.tunerdomes.com/index.php?_a=viewProd&productId=49
These are 1 watt and draw enough current to work with no "bulb out" error. I have not tried it yet, but I assume the same bulbs will work for the other 36mm festoons in the car. The first pic is a comparison between the 1 watt LED festoon and the stock bulb, the second pic just confirms the model of festoon bulb I used.
Good luck and enjoy.
A word of caution for the newer members who want to try this, please read the ENTIRE original post carefully and thoroughly before attempting. If you do it wrong, you will either break the bulb holder (trying to pry it off) or lose your wires inside your trunk lid.
