Hi there, how is the audio quality of these units vs the original MMI stock Bluetooth system? Would it be the same quality if I plugged my phone in via a wired connection instead of wireless?
Hi Soldier. I realise this was a while ago but can you remember were you found the CAN loom issue please as I have the same problem in that the original car mic will not work with Google voice assistant. thanksSo I finally got this fixed it seems. had to deeply take matters into my own hands, as I received no help at all. turns out it was a fault CAN loom cable...
Tested Siri out yesterday (very quickly) and all looks well!
Sorry I can’t recall, I’ve since done over 10 of these installs in b8’s and haven’t had the issue again.Hi Soldier. I realise this was a while ago but can you remember were you found the CAN loom issue please as I have the same problem in that the original car mic will not work with Google voice assistant. thanks
I had to fit it yes but others seem to have had more luck with the OEM mic and voice assistance than I did, I dont get interference on calls though so that is strange, are the two 2 pin plugs plugs on the loom still connected together, if so you could try un plugging those maybe. Testing the 2nd mic is a quick job as you can just plug it into the harness without fitting/running it up to the light just to check it will work for you.So I’ve managed to get my calls to work. Had to toggle the switch 8 to on. Then on the CarPlay select on. However I can hear like an interference buzzing noise. Not they end of the world. So then I guess to get the Siri/ voice control to work I need to wire in the other microphone for that.
