Hi all,
I have a constant notification on the dash of my '11 A5 that my right rear light/brake light is out, however it is working fine.. Can anyone tell me how to reset it?
Thanks!
it should reset itself.
the car will tell you a bulb is out if it detects that the resistance is too high or low.
try disconnecting the rear light, turn the ignition on and off, then reconnect it.
if that doesn't work change the bulb, heat may have played with the filament and taken its resistance out of specification.
2014 A4Q/8K 6MT MMI 3G+
@Gem -- Find a friend or local indy shop (not the dealer) that will scan the CECM/BCM for VAG fault codes, and report them here. Generic OBD scanners are not sufficient for this, BTW. --g
