Today I noticed a broken wire on what's seems to be a sensor located on a hose connected to the bottom of the radiator on the left side of the car (see pictures). (2015 A5 sportback 1.8T)
First I want to know which sensor is it and then the easiest and proper way to disconnect the connector in order to repair it.(do I have to push, pull, lift any tab, etc).
Hopefully I may disconnect it with one hand from the top and not having to lift the car, remove the pan, etc.
From top:
From top:
