As I am Stage 2, the general opinion is to upgrade the charge cooling system. This is more so in warmer climates.
I have done 2 rolling road sessions, both in 20+ degrees, one being when the car was remapped to Stage 2. I sufferred from high IATs, the max 80 C when the ECU pulls timing/boost and ultimately power, like down to 440bhp. It should be somewhere around 460/470.
So after this RR sesh and the warm summer, even though on the road the car goes like stink, I decided to upgrade the charge cooling, but on a budget as I didn't to spend £1000 on a kit for something that only causes a power drop in a small number of occasions.
I actually did this upgrade a couple of months ago, but only now getting round to posting a thread on it.
Anyway, I looked at the Jag heat exchanger, but I think it is only a single pass and wanted a multi pass unit to give the best effect on cooling. Also these were out of stock at time of searching. So I opted for a universal rad.
I have, prior to fitting the heat exchanger fitted a FIS Control and made mental logs of the IATs. They weren't too bad, after full warm up, hovering around the 60 degree mark.
I spent a couple of days modifying the rad to accept brackets and put a top bleed screw in. Making brackets, checking pipe routing etc. I have kept the OEM rad in place and placed the uni rad above it. So the pipe work goes into the bottom of the OEM rad, out of the top, then U turns into the bottom of the uni rad, out of the top.
I only managed to get 2 litres of coolant out of the std system and this was removing the OEM rad and tipping it up, plus pressure blowing the supercharger intercoolers through, so this will warm up pretty quickly on a stage 2! The Uni rad holds just under 1.5 litres, so it has added a decent amount of coolant to the charge cooling system.
But it is quite a neat install and so far it is keeping the IAT down. On average I would say around 10-15 degrees over just the OEM rad.
I also removed the OEM rad and gave it a clean by blowing it with compressed air in reverse of the normal air flow to blow out flys, dirt and dust. As you will see in the photos, is was a like peppered, so possibly not even as efficient as when new!
When refilling I used 30:70 antifreeze mix and DEI charger chill (like Water Wetter), to get a better temperature transfer in the intercoolers and rads. Not sure what difference it made, but it should help.
I have done some redline pulls through 3 gears and the IATs have only managed to just about touch 55 degrees!
I haven't done any scientific data logs or controlled experiments, I just know that the temps are not as high. :)
Before fitting the uni rad, the IATs would follow the oil temp up at the same rate as the engine warms, until about 50-60 degrees. Now with the additional uni rad, the IATs rise more slowly and follow the oil temp but at around 10 degrees lower.
I think it is a worth while mod and not worth spending a grand on a full tuner's kit, unless you going for all out power and stage 3 etc. :)
Tire Vehicle Wheel Automotive lighting Automotive tire
Trial fit before aluminium welding mounts, top bleed screw and painting black + removed half a tree of dead leaves.
Automotive tire Grille Road surface Wood Door
Protective plastic guard still lets debris pepper the rad.
Automotive fuel system Automotive tire Hood Motor vehicle Vehicle
Several hose clips, bit of joining hose and a U bend connect it up.
Hood Grille Automotive tire Automotive design Motor vehicle
Stainless hardware.
Automotive tire Grille Automotive exterior Bumper Motor vehicle
Grille Motor vehicle Hood Automotive tire Automotive design
Overall surface area is pretty close to a full replacement Merc racing rad! just doesn't hold as much water.
Urban design Building Rolling Engineering Track
The top of the uni rad is near level with the top of the grille.
Automotive parking light Vehicle registration plate Vehicle Tire Grille
Whilst I had the bumper off, I chucked an RS grille in too! :)
Discussion Starter · #6 ·
What did this mod cost?
It was around £190 + consumables like aluminium welding wire, coolant, paint.
Once you add everything up, you are nearly halfway to a Merc racing rad and subtract the time it takes to make everything from scratch like brackets, pipe bending etc would I do it again? Erm, I may be tempted to just buy the Merc racing rad and chuck it straight on! :D Depends if you're really tight on budget and don't want to spend the extra £250 or prefer the satisfaction of saving money and designing & making a kit from scratch all by yourself!? :) If we didn't have Merc racing in the equation, then yes I would do it again rather than spend £1000 on a kit!
Discussion Starter · #9 ·
Thanks Aide! :)
Yeah, the only reason to fit, is because 2 runs on the rollers in the summer has thrown up high IATs, not had an issue or noticed at any other time! :)
Hence why I didn't want to spend loads on it.
Will do! Will wait for the cool autumn weather first to make sure! :D
